Upper Hose Hot, Lower Hose Cold
Old Aug 23, 2008 | 09:25 AM
bow tie's Avatar
Default Upper Hose Hot, Lower Hose Cold
*updated*
1996 Honda Accord EX F22B1
is that a sign of thermostat going bad? when i'm at idle for 5+ min (operating temp) the radiator fan is not coming on. the fan does work when i jump the switch on the upper radiator hose but does nothing when i jump the switch on the thermostat housing. now what could that be?
-all air bubbles bled, new radiator cap.
-temp rises above middle marker after long drive but doesnt go to red (3/4).
-fan comes on when car is off.
*update*
-new thermostat didnt cut it, temp still rises.
-guessing it's either electrical or head gasket now but anyhow...
-just broke my budget and bought $600 worth of OEM parts to fix this damn cooling problem!
-parts include, new rad, new water pump, timing/balancing belts, gaskets, head gasket, etc. let just say....*******!
Modified by bow tie at 6:30 PM 8/27/2008
Old Aug 23, 2008 | 09:31 AM
Mr Yamada's Avatar
Default Re: Upper Hose Hot, Lower Hose Cold (bow tie)
Try a new thermostat, the other cause could be a plugged up radiator.
It would be useful information to know WHAT YEAR the Accord is.
The thermoswitch in the upper radiator hose line is for post engine run temperature control.
Some years of Accord have a sensor AND a switch at the T-stat housing.
Old Aug 23, 2008 | 10:05 AM
dtapia's Avatar
that opens up a lot more.
could have a failed fan motor,blown fuse, failed fan relay, failed fan timer,open in the wiring.are you sure your jumping the correct switch.
bradabu
Mar 14, 2011 02:42 PM
1991crx16
14
Jan 26, 2011 01:47 PM
supermotothud
Dec 19, 2008 01:38 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
spaceman
Sep 24, 2003 06:57 PM
