Qs about obd-0 to obd-1 ..
hey guys .. this is my first post ..
now i'm planning to convert my b16a obd-0 to 1 by my self without using the 'conversion harness' ..
so i got anew obd-1 dizzy, and replace the creame plug with the gray ..
and now i've some Q's :
1. what abt the 4 wire o2 >> i dont know what are these :
O2 Sensor signal
O2 Sensor signal Ground
O2 Sensor Heater Circuit Control
black heater circuit power
2. how can i remove the pins from the obd-0 plug ..??
3. i'm following the table here http://www.boosted.org/obd0.php?page=obd0 and i'm wondiring if i re pin the wires to the new obd-1 ecu plug and connect my p30 .. by that is the converting will be completed ??
NO NEED FOR MODIFY THE ENGIN HARNESS OR ANY THIG ELSE ??
thank
O2 Sensor signal
thank
