another car wont start thread
Old Aug 22, 2008 | 10:38 PM
Roi's Avatar
Roi
Default another car wont start thread
so whats up guys. i got a 93 coupe ex with stock motor. so i was driving down the block and the motor just died on me. the fuel pump isnt priming and im not getting fuel or spark. i already replaced the fuel pump, main relay, and ignitor in the distributor. i have no idea what to do next. any help would be appreciated. and i have done a search but with no luck. oh and ive checked all my fuses and they are all good as well.
Old Aug 22, 2008 | 11:46 PM
CTRwannaB's Avatar
Default FV-QR
timing?
broken belt?
Old Aug 23, 2008 | 09:21 PM
Roi's Avatar
Roi
the belt is fine cuz the rotor in the dizzy is spinning, and the timing was on perfect. i have no idea what to do. my pump still not turning on. can i take the ecu and dizzy from a 95 civic sedan to see if i can get it to start? or is that a no go?
Old Aug 23, 2008 | 09:36 PM
Paprika's Avatar
Default Re: (Roi)
*IF I REMEMBER CORRECTLY* you should be able to use the ecu and dizzy from a 95 sedan as long as:
- for ECU both cars must have the same type of transmission.
- for the dizzy both engines must be from the d-series family.
Did you check:
- UNDERHOOD fuses?
- Ignition Coil
- ACG Fuse (check it again, heck replace it if u have a replacement on hand)
I'm in a very similar issue as you. My 92 DX Sedan won't start either after having been running all morning. My fuel pump does prime however from what I can hear and my fuel line is under pressure...
So yeah what makes yours so strange is ur missing both fuel and spark which to me points to an electrical problem since both require electricity to work... hmm....
Old Aug 23, 2008 | 09:51 PM
Roi's Avatar
Roi
word. ill make sure and try and hook it up tomorrow. but yea no fuel or spark. my pump doesnt prime either. yea ive checked all the fuses. in car and underhood. if i cant get spark will the ecu tell the fuel pump not to turn on?
Old Aug 24, 2008 | 12:51 PM
Roi's Avatar
Roi
i also tried to get the cel code from the connector pin near the ecu but the CEL was just on the whole time instead of flashing. any ideas?
Old Aug 24, 2008 | 12:54 PM
Hanmin's Avatar
if you loss fuel and spark at the same time. Check the all the fuses. Or try checking your ignition switch, it controls both fuel and spark. Do you even have power? maybe your battery came loose. does your car crank still?
Old Aug 24, 2008 | 12:59 PM
Roi's Avatar
Roi
yea ive checked all the fuses under the dash and under the hood. but i havent checked the ignition switch. would that control the fuel pump somehow not to come on? and yes it still cranks
Old Aug 29, 2008 | 09:58 AM
Roi's Avatar
Roi
so i tried taking my distributor from my 95 civic sedan but it doesnt bolt up right. and also my ecu has a nasty smell? could it be cuz its fried? plz help
Old Aug 29, 2008 | 12:51 PM
blk92_d16's Avatar
Nasty smell? as in a burnt smell? Swap in another ecu...doesn't even have to be the right one really.
Old Aug 29, 2008 | 11:59 PM
Roi's Avatar
Roi
can i use one from a 95 civic sedan?
Old Aug 30, 2008 | 06:00 AM
Pothole987's Avatar
Default Re: (Roi)
as long as it is the same (auto or manuel) it'll work just to test
Old Sep 13, 2008 | 09:51 PM
Roi's Avatar
Roi
so i figured out what the problem was. my ecu was fried.i put in a new dizzy and i swapped out the ecu from my 95 sedan and it fired but was idling very bad. could that be because it was using the ecu from the sedan? and also is there a way to wrap or protect the ecu from water?
Old Sep 14, 2008 | 10:55 PM
Roi's Avatar
Roi
anyone?
Old Sep 15, 2008 | 12:41 PM
Roi's Avatar
Roi
so i got a new ecu and its runnin good. the Purple People Eater is back alive minus the idle. idles up a down between 900 and like 1400. anyone got any ideas as to what it is?
Old Sep 24, 2008 | 03:50 PM
blownb310's Avatar
Default Re: (Roi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roi &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to wrap or protect the ecu from water?
</TD></TR></TABLE>How did it get wet? Is the windshield seal leaking?
Old Sep 24, 2008 | 04:26 PM
94EG8's Avatar
Seagull Management
Default Re: (Roi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roi &raquo;</TD></TR><TR><TD CLASS="quote">so i got a new ecu and its runnin good. the Purple People Eater is back alive minus the idle. idles up a down between 900 and like 1400. anyone got any ideas as to what it is?</TD></TR></TABLE>
Bad or dirty IACV.
Old Sep 24, 2008 | 05:04 PM
Projekt Motorsports's Avatar
New User
Default Re: (94EG8)
if you didnt have that problem before it could be the computer re-learn
Old Sep 25, 2008 | 08:22 PM
Roi's Avatar
Roi
im not really sure how it got wet. all i know is that it rained the day before. so im assuming there is a leak somewhere cuz the carpet was wet.
Old Sep 26, 2008 | 12:35 PM
New User
Default Re: (Roi)
water may have come in by the wipers at the bottom of the windsheild
Ef4doorwagon
16
Nov 19, 2015 03:37 PM
LuckyJDM
Oct 30, 2014 03:14 PM
wasp9166
Feb 11, 2013 05:46 AM
eg2GAMEOVER
Feb 22, 2009 03:41 PM
gutted-dx
20
Jun 18, 2005 12:03 PM
