Oil in my spark plugs
Hi guys i was having a problem about 2 months ago with oil getting into my first spark plug so i thought i was the valve gasket seals so i replaced them with all new ones and dwhat not and i didn't have that problem anymore and iw as just recently looking under my hood cause i was bored and im now having that problem again but with all of the spark plugs can someone please help ono what i need to do thanks
ryan
ryan
that kept happening to me and i got sick of it so i dried off the area the orings contact the head and thoroughly cleaned the valve cover contact area. then i put a very thin layer of high temp silicone on both surfaces and let them dry for about 5 min placed the orings back in the valve cover and put it on and never had a problem sense hell i think i have had my valve cover off probably 10 times in the last 2 weeks due to the outer gasket but have never had problems with the orings leaking again. i haven't even reaplied the silicone to the head i just left the thin residue that was there after i removed the cover.
sounds to me you are doing a bad sequence on your torquin down the bolts
so hand tight from top center then bottom center and work right top and bottom then move left from center top and bottom then right top and bottom after they are all in start all over and you will see that they are all lose so hand tighten only.
dont over do it cause you will end up with broken bolts
dont remember how many bolts now but follow this sequence
firewall
9 5 1 3 7
10 6 2 4 8
radiator side
hope this helps.....
firewall
9 5 1 3 7
10 6 2 4 8
radiator side
SuicideSlide
Feb 14, 2007 04:53 AM
