lil question
fast question.. i have a 96 honda accord ... vtec.. about $30,000 into it.. etc... etc.. anyways
i cant get the 36mm bolt off the rotor thing so i can change the drive axle... its rusted on. any ideas? i hit the lock off too... the lil steel pin thing. still nothen. i tryed pry bar in between and a gun hoooked to compressor....
i was thinking wd 40? or propane torch? heat it up a bit.. then use gun?
no no no, screw wd-40, u gota got pick up a can of some PB Blaster. spray that axel nut a few times, wait like a hour and u will be able to take it off, when i take mine off i use a extendted socket wrench with the handle off of my car jack on the end for mor eleverage and it comes off real easy.
yes ill grab some pictures when i find my cam! lol... its a looker for sure... clean and all done up. just my paint job was $6000....body kit, tv, playstation 3 in car... navi/realtime guages... neons, hid's lowered off ground to 2" i got fulll suspension done, cold air intake, struts, cat back exsaust, dc sport headers, Nitrious, pistons, cams.... etc etc.... but this yr nitrious is history, going with a turbo!... i already picked it up, now its installing it..
there is some info intilll i shoot some pics!
anyways,
i tryed heating it up with torch ...nothen.... wd'40...nothen... that other stuff someone posted... still nothen... i unstaked the axle bolt... and im not to sure what im doing wrong.. i put a johnson bar with extended... with a fence pole.. thats approx about 8 feet... and bent the ppole.... and yah... hahaha.. wut to do now!
im about to selll the car! for 8 grand! hahaa... and mabe look into a skyline or something.
anyways, any info what be nice...
p.s.. when i do get my cam... how do i post pics?
anyways,
i was jus thinkin... ur axel nut might be welded on, i know some of them were. did u pick up some PB blaster? works 100% beter than wd-40. but if its welded on im not sure, maybe a torch will unweld it.
but i cant believe u got all that done to ur car and u cant figure out how to take taht off lol
Try turning up the working pressure on your compressor. It'll give your "gun" more torque. If that doesn't work, borrow a bigger impact wrench. Or, you could take it to a shop and have them pop it off and put it back on, looser, and with some grease. They might not even charge you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gemineye716 »</TD></TR><TR><TD CLASS="quote">i was jus thinkin... ur axel nut might be welded on, i know some of them were.</TD></TR></TABLE>
Why would an axle nut be welded on?
The impact never worked for me. I just use a breaker bar with a 4 ft cheater pipe. Wheels on the car, car on the ground. and someone holding the brakes while I unscrew it. It worked every time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickoz »</TD></TR><TR><TD CLASS="quote">
i cant get the 36mm bolt off the rotor thing so i can change the drive axle..</TD></TR></TABLE>
Weld a wrench on it. lol. I got that from some other member on this site, thought it was funny. Anyway you say you have put $30,000 of work in the car. You say you are going to sell it for 8k. Why? Just don't understand since you said just your paintjob was $6000. What did you paint it with? JDM War Paint that the Greek God Zeus used?
Care to explain?
Care to explain?
keep this thread on topic of discussing how to get the axle nut off...
to answer your question though, this always worked best for me as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord »</TD></TR><TR><TD CLASS="quote">I just use a breaker bar with a 4 ft cheater pipe. Wheels on the car, car on the ground. and someone holding the brakes while I unscrew it.</TD></TR></TABLE>
also, how in the world did you actually bend a fence pole without twisting the drive off the ratchet or breaker bar, or just without breaking something period?? don't see how that could happen unless it was a cheap fence pole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">don't see how that could happen unless it was a cheap fence pole.</TD></TR></TABLE>
It probably was a plastic one.
alacard
Oct 9, 2005 05:54 PM
