Speakers stop working for a couple sec then turns back on. What could be the problem?
Old Jul 23, 2002 | 06:28 PM
Dc5-Power's Avatar
Default Speakers stop working for a couple sec then turns back on. What could be the problem?
My system has never had a problem until yesterday. While i'm listening to music, all 4 speakers stop working at the same time, but my sub still bumps, then after a few seconds the speakers start to work again. At first, i thought it was the cd, but i'm sure it's not the cd's because the radio does the same thing too. This problem only seems to happen when i have the music up. So what could be the problem?
My setup:
Pioneer deh-p9200r Headunit
Infinity Kappa's all around
Pioneer 4 channel amp
JBL mono sub amp
Old Jul 23, 2002 | 07:48 PM
SoCal ITR's Avatar
Default Re: Speakers stop working for a couple sec then turns back on. What could be the problem? (kimchee_p
Maybe a grounding problem? Just a thought though.
Old Jul 24, 2002 | 12:38 AM
Dc5-Power's Avatar
i have no idea if that's the problem, but i'll check it out
anybody else have any idea on what the problem could be?
Old Jul 24, 2002 | 09:58 AM
GSRaCeRbOI's Avatar
I'm not sure how your system is hooked up..
are the door speakers hooked up to the head units amp? or are you using 2 ch to run all 4 door speakers.. and bridged 2 ch to run your subs?
it could be a bad ground.... or other connection.. but its probably time to turn down your gains..could be the thermal protection kicking it... I hope its not clipping...
tell us how you have everything wired...
Old Jul 24, 2002 | 06:43 PM
CRXSiR500's Avatar
Let your car run with the system on, and watch the "overheat" lamp on your amp while it is playing. It did that all the time in my CRX and i figured it out after a while.
Old Jul 24, 2002 | 09:54 PM
Dc5-Power's Avatar
My 4 channel amp is powering up my 4 speakers.
So the problem could be my connections or my amp?
Old Jul 24, 2002 | 11:49 PM
Jonathan_ED3's Avatar
as long as you know they're not clipping out (you should know if that happens), it's almost ALWAYS going to be a bad ground/connection somewhere in the lines.
Manolo
Audio / Security / Video
Nov 11, 2005 07:21 PM
93civicEX
Jan 25, 2005 06:55 AM
MikeHock
Mar 30, 2004 05:10 PM
