Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Bad Front End Shake
Old Aug 22, 2008 | 02:49 PM
SlowCG's Avatar
Default Bad Front End Shake
I have a 2003 Honda Accord V6 6speed and when I really get into it the car shakes very badly once I hit about 4K and redline it. Its fine when cruising and stopping but during acceleration there is some bad shaking espesially in 2nd gear. It seems to have started after I installed my AEM v2 but all connections are secure there so im not sure what the hell is going on. Any help is appreciated. Thanks!
Old Aug 23, 2008 | 04:37 AM
MSchu's Avatar
My Name is Nobody
Default Re: Bad Front End Shake (SlowCG)
it could be several things from a failing CV joint to a bad engine mount... have you been doing any hard launches with that new intake?
Old Aug 23, 2008 | 07:33 AM
SlowCG's Avatar
Default Re: Bad Front End Shake (MSchu)
No hard launches. And its not a broken motor mount we already checked that. Right now im thinking its bent axles.
Old Aug 23, 2008 | 10:52 AM
MSchu's Avatar
My Name is Nobody
CV is better bet
Old Aug 23, 2008 | 05:24 PM
cjo_28's Avatar
From what you describe, it sounds like a bad inner cv joint. It's a pain to isolate the bad axle, though, so good luck.
If you take it to a shop, they'll probably give you an estimate for both axles to save the headache of guessing the wrong axle.
Old Aug 24, 2008 | 09:07 AM
SlowCG's Avatar
Default Re: Bad Front End Shake (cjo_28)
Is there a way to tell which axles is the bad one?
Old Aug 24, 2008 | 03:32 PM
cjo_28's Avatar
You would need to remove BOTH inner cv joints for an inspection. Usually you will feel a groove on the surface of the inner joint, the part that the bearing "rides" on.
If the vehicle doesn't use an intermediate shaft (the '03 V6 uses one), you can swap inner cv joints and forget about the problem since you'll never notice the vibration in reverse (the bearings will now ride on the opposite side of the joint, the side that doesn't have the groove, when driving forward).
Old Oct 1, 2008 | 08:02 PM
RichmondLX's Avatar
I had something similar, it was a bad inner cv joint. What I was experiencing was a real harsh front in shake when I would hit the brakes hard.
Jose-aka-Pedro
Jun 1, 2007 06:56 PM
Supa_Slow_Civic
Oct 16, 2005 05:46 AM
G1 TEGGY
Aug 17, 2004 04:34 PM
xhatchracerx
Oct 23, 2003 01:05 PM
e_r_i_c_
Apr 28, 2003 07:55 PM
