B18a1 Rebuild Question ~
Hey HT! I searched around and really couldn't find much for my question! I got an old 1993 3dr LS integra off my buddy for basically nothing, and I've always wanted a DA more than anything, so I have some serious plans ahead. The engine itself has about 220,000km, and the clutch is completely blown, probably needs a new tranny as well. Keep in mind that I am not familiar with many terms and I am kinda new to this whole thing. Now after some research I've decided to stay away from a swap and and stay away from vtec completely (preference), and I've decided to do a complete rebuild, and go boost in the near future. Now here is my question, when i bring my motor to a machine/motor shop, what should I be asking for, for a reliable DD that can be boosted in the future? Should I get a bore so I can run bigger pistons for higher compression? or keep it low and go safe. Should I replace all parts back to OEM or do some aftermarket so there will be no strain on the motor when it is boosted?
Currently I have this on my list. PLEASE tell me if I missed anything, because that is what this topic is for!!!
TOP END GASKETS
TOP END SEALS
BOTTEM END GASKETS
BOTTEM END SEALS
WATER PUMP
OIL PUMP
TENSIONER
TIMING BELT
ROD BEARINGS
CRANK BEARINGS
PISTONS/RINGS
DISTRIBUTOR
ALTERNATOR
ROD BEARINGS
Thanks in advance!!
TOP END GASKETS
TOP END SEALS
BOTTEM END GASKETS
BOTTEM END SEALS
WATER PUMP
OIL PUMP
TENSIONER
TIMING BELT
ROD BEARINGS
CRANK BEARINGS
PISTONS/RINGS
DISTRIBUTOR
ALTERNATOR
ROD BEARINGS
Thanks in advance!!
brandCRX
Aug 18, 2001 12:39 AM
