k24 in crx
Old Aug 22, 2008 | 08:34 AM
k24_crx's Avatar
Default k24 in crx
i'm looking for some information in doin a k24 swap in an 88 crx si
Old Aug 22, 2008 | 08:43 AM
MyHotsh's Avatar
Default Re: k24 in crx (k24_crx)
https://honda-tech.com/zerothread?id=1853644
Old Aug 22, 2008 | 03:50 PM
k24_crx's Avatar
Default Re: k24 in crx (MyHotsh)
thanx that will help me out...i've done lots of swaps in other cars but this is my first honda swap but it looks simple enough...
Old Aug 22, 2008 | 04:00 PM
EDwEFprts's Avatar
http://www.k20a.org/forum/
Old Aug 22, 2008 | 07:28 PM
k24_crx's Avatar
Default Re: k24 in crx (EDwEFprts)
i am also wanderin about the bottom end in the k24 what are my options with building it i looked around a lil bit and found a few odds and ends but i'm not sure what the best parts are to put in it
Old Aug 22, 2008 | 09:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
what do you want from the bottom end and over all motor?
Old Aug 23, 2008 | 11:09 AM
k24_crx's Avatar
Default Re: k24 in crx (***$nyper)
i'm looking to get the most i can out ot the engine and still be able to jump in it and drive it on a trip and not worry about it coming apart and possibly running it boosted later on. i'm also looking to run a k20a2 head
Old Aug 23, 2008 | 05:11 PM
IndySporty's Avatar
Well if you're going to boost it you don't want a very high compression ratio, which equals not nearly as much power as you could run without a turbo. You could trade off and go with a mid range compression ratio to get something like stock power levels or a little better and then when the turbo goes on you're already built. Any K-swap in a crx that is running correctly should be significantly faster than stock whether it's turbo or not. You could get into the 12's without a turbo on a "daily driveable" K-RX. You need to PM CRXBart and talk to him about the K-RX. He probably has more insight on this topic than others.
blazzer
25
Nov 28, 2009 09:49 PM
Dmen
Classic Hondas
Jun 27, 2009 11:36 AM
zero pistons
Oct 30, 2006 09:20 AM
74 burban
Jun 12, 2004 07:28 PM
axtv
10
May 25, 2003 10:52 AM
