So I hit two huge potholes today...
Old Aug 21, 2008 | 10:19 PM
JTN416's Avatar
Default So I hit two huge potholes today...
My car is lowered, about 5-6 inches more until it touches the ground. I hit two big potholes that I forgot to dodge, and my car made a sound that seemed like my bumper fell off. One of the potholes was a raised sewer, and I went slowly over it again and my bumper doesn't touch it. Did I scrape my oilpan or did I bottom out my suspension? The other was a normal pothole and it made the same sound. I'm paranoid as crazy.
Old Aug 21, 2008 | 10:48 PM
TOO MUCH TORQUE's Avatar
ARE YOU 15?
GO CHECK HOW ARE WE SUPPOSE TO TELL YOU?
Old Aug 21, 2008 | 11:00 PM
JTN416's Avatar
Default Re: (TOO MUCH TORQUE)
lol? I already checked, and everything seems fine, just asking others for their opinions, if you don't have a useful comment, then don't post. Are you 12?
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">ARE YOU 15?
GO CHECK HOW ARE WE SUPPOSE TO TELL YOU?</TD></TR></TABLE>
Old Aug 21, 2008 | 11:58 PM
BamBamDB1's Avatar
Default Re: (JTN416)
Its normally your cross member that hits the ground, Or your oil pan... You probably just scraped up the cross member, dented it or your oil pan... Its not a really big deal. Just try to avoid them next time. My cross member needs to be replaced, my radiator doesn't fit flush as it should. And i've already had to replace the oil pan.
Old Aug 22, 2008 | 12:40 AM
__oversea's Avatar
Default Re: So I hit two huge potholes today... (JTN416)
yeah, check the oil pan for dent, it could block the oil pick up line from the dent.
Old Aug 22, 2008 | 10:01 PM
mr.beeks's Avatar
Default Re: So I hit two huge potholes today... (__oversea)
check you upper ball joints.. lift tires and wiggle it see if they are loose..
Old Aug 23, 2008 | 07:17 AM
letsdrive's Avatar
yeah there is tons of stuff that could of hit. front tow hooks, radiator support, etc....go do some exploring under you car. you probably could figure this out on your own.
Old Aug 23, 2008 | 07:21 AM
EkFG's Avatar
Default Re: (letsdrive)
Id check the oil pan frame rails and the exhaust, most common **** to bottom out,.
Old Aug 23, 2008 | 12:06 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: (EkFG)
If you have a aftermarket header it could of been that...
Old Aug 23, 2008 | 12:39 PM
310Integra's Avatar
the pothole i hit was a little one not even deep but i was going 50 or so, i scraped my header and oil pan and my front upper control arm hit the engine bay making a little ding. i took everything off and no damage that will affect anything happened.
zach1288
Jan 10, 2007 02:09 PM
U N S E E N.
Jul 28, 2006 08:08 AM
JOEP
Jan 26, 2004 09:53 PM
Scartissue
Nov 25, 2002 11:49 AM
