What GSR Bolt-ons to get ?
I just orderd a JDM B18C GSR for my EG Hatchy ive got a 6 puck act and nice 4-1 header 2.5 to a magnaflow exhaust what else could i do to it i want to keep internals as stock as possible because i will be daily driving it
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Save the money on the throttlebody, send yours out to maxbore and have them bore it to 65mm. Skunk2 Intake manifold is a nice unit, has a much better casting than the Blox unit. Test pipe, and you said you wanna keep the internals stock. After that it would be cams and a tune.
My friend has a USDM GS-R and I'll be installing the following parts/bolt-ons:
Hytech Replica Header (small tube)
BPi Velocity Stack (3")
Skunk2 ProSeries Intake Manifold
JDM ITR Throttle Body
Hondata IM Gasket
Spoon 2-Layer Headgasket
ITR Camshafts
ITR Valve Springs
and getting it dyno tuned on CromePro.
Hoping to hit 180whp. I think we should be able to accomplish this.
Hondata IM Gasket
ITR Camshafts
ITR Valve Springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ic3man19 »</TD></TR><TR><TD CLASS="quote"> ive got a 6 puck act </TD></TR></TABLE>
Why that clutch on a motor that is generating 110 wtq max?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artin01 »</TD></TR><TR><TD CLASS="quote">How abut blox throttle body and intake manifold and a v2 cold air intake u should be set.</TD></TR></TABLE>
That is GREAT advice on how to make the car slower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet »</TD></TR><TR><TD CLASS="quote"> throttle body</TD></TR></TABLE>
Whats wrong with the stock one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMThoughts »</TD></TR><TR><TD CLASS="quote">Save the money on the throttlebody, send yours out to maxbore and have them bore it to 65mm.</TD></TR></TABLE>
See above.
See above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ic3man19 »</TD></TR><TR><TD CLASS="quote">I just orderd a JDM B18C GSR for my EG Hatchy ive got a 6 puck act and nice 4-1 header 2.5 to a magnaflow exhaust what else could i do to it i want to keep internals as stock as possible because i will be daily driving it</TD></TR></TABLE>
You could do a lot in terms of bolt-ons, but what you should do depends on what your goals are. Are you shooting for a #?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">
See above.
Just from speaking with tuners, as I put my setup together to reach my goals, they have all said instead of buying a new unit, just send yours out for a rebore. It gets you the size desired and the plate won't stick. That's was the basis for my statement. For the 100 dollars it costs, it is much more cost effective than buying a new unit.
See above.
WOW thanks for all the advice as far as the 6 puck it came with the car things im most likely getting are
Skunk2 Intake mani and TB
password jdm intake mani gasket
CTR Cams
possibly prelude injectors
and a tune on CromePro
as far as injectors would it hurt to throw on some bigger ones
CTR Cams
You're right nothing is wrong with stock one.
im running the blox im personally i have no idea what it did versus the oem IM. but at this time no turning back now. 4-1 headers do kinda suck imo more power and torque out of a tri y setup. cai do make more power but they should be properly installed with your setup not usually just bolted on it wont make the max performance. And many will tell you with boltons you shoudlnt waste time in tuning. me on the otherhand recommend it. i should be doing mine sometime soon i hope and will show a difference in the power
wasanissanFL
11
Feb 19, 2015 11:08 AM
MikeySpec
149
Jan 25, 2015 06:53 PM
ninjaman
Jul 18, 2001 09:55 AM
