real bad fumes
ok so ever since i got my Si it seems to smeel bad when i drive , like oil/gas vapors when i get on it a bit or if i moreso when i menuvor the car around.
i have no exhaust leak and my tip goes out past the bumper.
anyone ever experience this?
please help its giving me a headache , literally.
stock 93 si no cel, just a intake and exhaust
I drive coupes, but the same thing happens to me if - like I'm hauling something with the trunk open - exhaust gets sucked into the passenger compartment, sooo...
I'd check the seals in the back of your car and make sure the exhaust isn't get past them...
Can I come over? I wanna get high!
Nah I'm messin around. Does it smell like raw gas?
I can't stand it when I drive behind people without cats. It really sucks as well when I have the AC on and my AC sucks in that STRONG *** EXHAUST! Gives me the worst headache ever!
I drive a 93 hatch and know that if the rear glass is even cracked open a bit it will pull exhaust fumes right inside. I would get it alighned and closed all the way and see where you are at that point. I have also had the rear main oil seal go out and it leaked oil right on the header down pipe and the fumes would come into the cabin. but I would start at the rear hatch first
yea i just realigned the glass to shut better!
i was underneath my car yesterday and its surpriseingly dry as hell
ima go for a test ride in a minute to see if it helped!
test drove and still had the fumes, not as much but its still there, i now turned my muff tip down and i notice that on one of the vents for the charcoal canister was clogged , so i poked it thru once again ill go for a test drive and hope it works
akus2ki
Feb 25, 2023 04:00 PM
Layziebtnh055
Apr 28, 2004 04:56 PM
