No power to fuel pump
So yeah, the fuel pump is not getting any power.
I tried 2 different main relay and re-soldered every connections as per the "quick fix" suggested somewhere else. It's possible both relays are bad. Which pin of the relay do I need to check for power going to the fuel pump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HitF8 »</TD></TR><TR><TD CLASS="quote">Maybe the pump is just shot, not sure which pin it is to check for power. </TD></TR></TABLE>
Tried 2 different pumps then decided to hook the voltmeter to the pump plug. That's when I realized it wasn't getting any power.
A link on that page did help.
http://www.tegger.com/hondafaq....html
I'll look up pin #7 tomorrow night
Thanks for the link.
I disconnected the harness from the fuel pump, hooked a voltmeter into the harness, turned ignition on and off, and got nothing. Not even a flicker on the voltmeter.
Where's is the ECU fuse? Which # is it? Is it just a regular blade fuse?
Ok, according to a manual I'd have to check:
Under dash; fuse #18 > PGM-FI ECU Main Relay 7.5A
Under hood; fuse #31 > PGM-FI Main Relay 15A
Under hood; sue #32 > PGM-FI ECU, Clock 7.5A
Modified by blaze_125 at 11:04 AM 8/22/2008
So here's the latest.
I removed the main relay
Jumped wire 5and7, turn on the ignition and fuel pump started running.
This leads me to beleive I have 2 deffective main relays(cause I tried 2 relays) but I'd like someone who knows more than me to confirm this.
I've seen this issue a time or two before and never figured it out. Eventually I ended up hardwiring the fuel pump to the fuse box under the dash. There's a pin there that gives appropriate voltage when the key is turned on.
rupensane
14
May 16, 2009 12:28 AM
