Driver side axle problem help!!!!!
Old Aug 21, 2008 | 03:35 PM
DeDonDeRosa's Avatar
Default Driver side axle problem help!!!!!
ok here the deal, my buddys 94 LS teg, for some reason keeps blowing the drivers side axle inner joint. it doesnt matter what brand we put in there it keeps going bad. and the other side is perfectly fine. the only thing i can think of is could it be the rear motor mount?? if its bad? i dont get why it would keep blowing only the driver side. let me know what you guys think
then it gets a really bad vibration under acceleration what would cause the inner joint to keep going bad
Modified by DeDonDeRosa at 6:00 PM 8/21/2008
Old Aug 22, 2008 | 12:27 PM
Default Re: Driver side axle problem help!!!!! (DeDonDeRosa)
how can no one on here know what would cause the problem
Old Aug 22, 2008 | 04:18 PM
1992Si's Avatar
Are you using the cheap lifetime replacement axles ?
I had to go through as many a 4 to get a good one.
Old Aug 23, 2008 | 08:45 AM
Default Re: Driver side axle problem help!!!!! (1992Si)
we've used both oem and cheap and the inner joint keeps taking a ****
Old Aug 23, 2008 | 09:31 AM
1992Si's Avatar
Ok back to basic's
How low is the car ?
How old are the mount inserts ?
How much HP ?
Old Aug 23, 2008 | 03:21 PM
the car is really low
the mount inserts are prob 6 months old we only did the 2 fronts we didnt do the rear mount insert
LS integra with intake and exhaust
Old Sep 15, 2008 | 06:26 PM
S1NFUL RL1 619's Avatar
if the car is really low.. could it be possible that the streets that the car is driven on have plenty of bumps where the inner joint could scrape?
Old Sep 15, 2008 | 08:54 PM
socalej2's Avatar
Default Re: Driver side axle problem help!!!!! (S1NFUL RL1 619)
Like S1NFUL RL1 619 said, it could be due to your ride height. On my civic coupe the cv joints blew soon after I slammed my car but i dont know if that was the actual cause. But on your car its the inner joints so maybe it scrapes on bumps and dips?
SlickC95
May 23, 2012 09:35 PM
Closenough
May 4, 2012 08:30 AM
Civicfanatic_09
Oct 6, 2009 02:45 PM
Rocks
Jun 30, 2004 07:47 AM
sunlei
Mar 21, 2004 06:10 PM
