need help, doing battery relocated.
Old Aug 21, 2008 | 12:00 PM
lilo_goki's Avatar
Default need help, doing battery relocated.
okay, i'm doing battery relocate and fuse box relocate, i was just wondering if i can just run the power wire from the battery to fuse box, and then connect it from the fuse box to the starter. will it be okay, or should i just run it separate.
Old Aug 21, 2008 | 09:07 PM
lilo_goki's Avatar
Default Re: need help, doing battery relocated. (lilo_goki)
bump!!
Old Aug 21, 2008 | 09:12 PM
Hanmin's Avatar
yeah itll be okay. I think your talking about this.
Battery---fusebox---starter
instead of the normal fusebox---batery----starter.
Old Aug 22, 2008 | 01:47 PM
lilo_goki's Avatar
Default Re: (Hanmin)
yep alrite thanks, i didn't want to use 2 13ft wires.
lilo_goki's Avatar
would 4 gauge be good enough for the ground and power wires, or should i get 2 gauge.
Old Aug 22, 2008 | 03:46 PM
zacatkings's Avatar
Default Re: (lilo_goki)
im using 4 gauge without a problem. The only thing different i am doing is i have battery post mounted on my firewall and i am using them as a distribution block. So i have a cable from my battery to the back of the post, then a wire to the fuse box. The starter wire runs from the post to the starter. This set up has worked awesome for me so far.
notnic3
Jun 12, 2017 11:26 AM
chillerice
Feb 20, 2013 07:48 PM
vesperfx
Audio / Security / Video
Jun 27, 2008 07:34 AM
jimihendrixbro
Nov 23, 2007 10:39 PM
smash fascism
Apr 6, 2005 03:03 PM
