need help please!
Old Aug 21, 2008 | 11:42 AM
gizzerhatch's Avatar
Default valves tapping (i believe)
i have a bar'd jdm B18c in my eh3 and it sounds as if my valves are tapping... so i adjusted all the valves and it helped a little bit but its still apparent and I'm not sure what i should try next. anyone had this problem before? and help would be very much appreciated.
Modified by gizzerhatch at 9:46 PM 8/21/2008
Old Aug 21, 2008 | 11:43 AM
davefromPA's Avatar
Default Re: need help please! (gizzerhatch)
did you follow a guide to adjust your valves or just tighten them all a little?
Old Aug 21, 2008 | 11:46 AM
Default Re: need help please! (davefromPA)
i adjusted them to spec. i believe it was 0.006- 0.007 on the intake and 0.007-0.008 on the exhaust
Old Aug 21, 2008 | 01:20 PM
bump
Old Aug 21, 2008 | 02:26 PM
please anyone?
Old Aug 21, 2008 | 02:53 PM
revlimitx04's Avatar
It might be more effective if you put the actual problem in the title instead of just need help please.
Old Aug 21, 2008 | 08:49 PM
Default Re: need help please! (revlimitx04)
bump
p.s.
i cant change the title.
Old Aug 21, 2008 | 08:51 PM
sageuvagony's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 &raquo;</TD></TR><TR><TD CLASS="quote">It might be more effective if you put the actual problem in the title instead of just need help please.
Exactly! It's really annoying to see titles like that because if we want to follow up on your problem, we forget which thread it is. I'm going to end up not reading threads that say "HELP PLEASE!!!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gizzerhatch &raquo;</TD></TR><TR><TD CLASS="quote">bump
p.s.
i cant change the title.</TD></TR></TABLE>
We're just letting you know that from now on don't do that Thanks
gizzerhatch
19
Sep 10, 2008 10:34 AM
RyanG
Dec 12, 2006 12:10 PM
vtecsi00
Oct 15, 2006 12:42 AM
DARKSIRACER
Jan 16, 2005 03:27 PM
