valves tapping (i believe)
i have a bar'd jdm B18c in my eh3 and it sounds as if my valves are tapping... so i adjusted all the valves and it helped a little bit but its still apparent and I'm not sure what i should try next. anyone had this problem before? and help would be very much appreciated. http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
Modified by gizzerhatch at 9:46 PM 8/21/2008 |
Re: need help please! (gizzerhatch)
did you follow a guide to adjust your valves or just tighten them all a little?
Re: need help please! (davefromPA)
i adjusted them to spec. i believe it was 0.006- 0.007 on the intake and 0.007-0.008 on the exhaust
bump
please anyone?
It might be more effective if you put the actual problem in the title instead of just need help please.
Re: need help please! (revlimitx04)
bump
p.s. i cant change the title. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 »</TD></TR><TR><TD CLASS="quote">It might be more effective if you put the actual problem in the title instead of just need help please.
</TD></TR></TABLE> Exactly! It's really annoying to see titles like that because if we want to follow up on your problem, we forget which thread it is. I'm going to end up not reading threads that say "HELP PLEASE!!!" <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gizzerhatch »</TD></TR><TR><TD CLASS="quote">bump p.s. i cant change the title.</TD></TR></TABLE> We're just letting you know that from now on don't do that https://honda-tech.com/forums/images...es/emsmile.gif Thanks |
