rebuilding my motor to stock specs have a fw questions (k20)
Old Aug 21, 2008 | 09:25 AM
Evil Smile's Avatar
Default rebuilding my motor to stock specs have a fw questions (k20)
hey guys
i bought a RSX with spun bearing for cheap and now im rebuilding it. i have a few questiont that i would really appericiate if you could help me with. BTW the car has 90k on it.
1- what parts do you guys recomend i change while im at it?
2- once i take the head off, can i reuse the head studs? or do i have to get new ones.
3- do i need to get the head remilled? or can i just reuse it?
thanks alot
Old Aug 21, 2008 | 03:10 PM
Evil Smile's Avatar
Default Re: rebuilding my motor to stock specs have a fw questions (Evil Smile)
no one wants to help?
Old Aug 22, 2008 | 03:46 PM
Evil Smile's Avatar
wow no one wants to asnwer me?
Old Aug 22, 2008 | 04:34 PM
ruffrhyder's Avatar
New water pump, oil pump, new seals, (rear main, crank, cams, etc.) and of course the bearings, and rings, don't reuse the head bolts, get new ARP studs, and have the head and block decked to ensure proper sealing. Good luck
Old Aug 22, 2008 | 04:40 PM
king06's Avatar
dont know much about k's but, rings, seals, bearings, water pump, i wouldnt mess with the oil pump. About the milling, when i did my gsr i did it because it had little scratches, and because its safe insurance an its not that much. to get the head vaccumed and milled it was $120, two of the valves were leaking, so that was fixed. i reused my studs but, there arp.
Good luck
Old Aug 22, 2008 | 06:59 PM
Godspeed07's Avatar
Default Re: rebuilding my motor to stock specs have a fw questions (king06)
might want to try the tech forum......although this is "all motor" and well your rebuilding your motor, its not so much performance related.....but like everyone said, water pump, rings, seals, bearings....i would do the oil pump too.....curious to know why you wouldn't.....anyway id have anything related to the area of problem checked, such as the crank....just to see if things are still within spec...i dunno im a little paranoid like that. Id also get new head studs or go with the arp ones.....milling isn't a bad idea, however might just want to find out if it even needs to be done....see if you can find somewhere to measure it for you...or do it yourself Good luck bro.
Old Aug 22, 2008 | 11:12 PM
Evil Smile's Avatar
Default Re: rebuilding my motor to stock specs have a fw questions (Godspeed07)
thanks so much guys. i just took everything apart today, and guess what <U>CYLINDER #4 HAD NO BEARINGS WHATSOEVER. THE ROD WAS JUST PLAYING ON THE CRANK. </U>There is a ton of metal shavings in the pan. im gonna get the head milled and the block cleaned tommorow.
91civicEX
115
Apr 19, 2016 05:44 PM
Cd5bo
Nov 26, 2011 11:06 PM
lsvtechatch92
Feb 10, 2010 07:07 PM
mafia
Apr 9, 2009 12:53 PM
JohnnysEG
Feb 16, 2004 06:40 PM
