DC2 Cluster in EK?
Old Aug 21, 2008 | 08:38 AM
specoperformance's Avatar
Default DC2 Cluster in EK?
What is needed to do this? Will the DC2 cluster plug in and work properly? How is the fitment? Any pics? The search only brings up FS threads
Old Aug 21, 2008 | 08:50 AM
Hanmin's Avatar
it should mount perfectly, youll just need to rewire the plugs.
Old Aug 21, 2008 | 02:17 PM
Default Re: (Hanmin)
anyone know for sure?
Old Aug 21, 2008 | 02:19 PM
-Gambit-'s Avatar
Default Re: (specoperformance)
not a perfect fit but close. you have to re-pin the connectors to make it work
Old Aug 21, 2008 | 02:23 PM
DC5_lov3r's Avatar
Default Re: (-Gambit-)
check it out brah
https://honda-tech.com/zerothread?id=1053318
Old Aug 21, 2008 | 02:41 PM
Default Re: (DC5_lov3r)
exactly what i was looking fer..thanks
Old Aug 21, 2008 | 05:21 PM
anyone seen the bezel modified for a cleaner look?
Old Aug 22, 2008 | 08:33 AM
that thread didnt specify, do you need the DC2 plugs or can you just move the wires around from the EK plugs?
Old Aug 22, 2008 | 11:24 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specoperformance &raquo;</TD></TR><TR><TD CLASS="quote">that thread didnt specify, do you need the DC2 plugs or can you just move the wires around from the EK plugs?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegraboy &raquo;</TD></TR><TR><TD CLASS="quote">The repinning process will only work on EK Civics because they use the same plugs as Integras. The EG wire pins are too large to fit into the EK Civic/Integra cluster plugs.</TD></TR></TABLE>
It does specify. You need to repin the EK plugs.
Old Aug 22, 2008 | 05:17 PM
EF_9's Avatar
i did do this swap the plugs are fine all you need to do is re-pin the wires. as for fit ment i just placed it in there no modification really except for just positioning it. it wasnt screwed down or anything. took about a an hour to wire it up and fitting it. look nice IMO
Old Aug 22, 2008 | 05:25 PM
geneeunit's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">i did do this swap the plugs are fine all you need to do is re-pin the wires. as for fit ment i just placed it in there no modification really except for just positioning it. it wasnt screwed down or anything. took about a an hour to wire it up and fitting it. look nice IMO</TD></TR></TABLE>
yeah, i did the swap a while ago too, and its really quite easy. just re-pin the wires and good to go. im going to take the extra step and mold the integra outer bezel to my civic's outer bezel so its clean and looks like OEM. most likely with fiberglass and then just respray it with trim paint so it will be clean.
Old Aug 22, 2008 | 05:52 PM
Default Re: (geneeunit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geneeunit &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, i did the swap a while ago too, and its really quite easy. just re-pin the wires and good to go. im going to take the extra step and mold the integra outer bezel to my civic's outer bezel so its clean and looks like OEM. most likely with fiberglass and then just respray it with trim paint so it will be clean. </TD></TR></TABLE>
also my plan
Old Jul 3, 2010 | 07:40 AM
Spoonson's Avatar
Default Re: DC2 Cluster in EK?
Any specific graph show how to repin the wires of the EK plug??
dimitrisak
Mar 6, 2017 01:50 AM
Joshm88
Oct 30, 2008 05:13 PM
calisolekidd
Mar 8, 2007 09:56 AM
sleepinggsr
Jul 11, 2006 11:19 AM
757_7thgen
Oct 8, 2005 08:19 AM
