viper(791XV), how do i wire the neutral thing and the remote start?
Old Aug 21, 2008 | 07:23 AM
Hanmin's Avatar
Default viper(791XV), how do i wire the neutral thing and the remote start?
Apparently I need to be spoon fed, heres where I'm at with the remote start, im pretty sure I have everything right buttt the "starter side and key side part"
I just did this to the ignition wire hoping itll work Key-----|-|-----plug---eventually starter.
I just put the key side the one closer to the key, and the other one whatever. And do I have to hard wire the remote start module thingy to the main brain?? or is that plug all it takes?
I did like some of the door sensors for the neutral thing, but I figured I get remote start working first, so I can keep testing. But I might as well ask for help now=].
Modified by Hanmin at 9:19 AM 8/21/2008
Old Aug 21, 2008 | 11:21 AM
B18C_EJ8's Avatar
Default FV-QR
You've got the key side / starter side wiring correct.
However, the "neutral thing" has nothing to do with the door sensors.
Old Aug 21, 2008 | 11:48 AM
Hanmin's Avatar
thought it ran by when you open and close the door. will the tach wire not being connected cause it not to start, because I just remembered I didn;t wire that up.
Old Aug 21, 2008 | 11:59 AM
B18C_EJ8's Avatar
Default FV-QR
As stated previously, the neutral safety wire has nothing to do with the door sensors (or, more properly, door triggers). What does the instruction manual say to do with that wire?
The tach wire doesn't need to be connected, as there's a programming option to change it from "tach sense" to "voltage sense", but it's a "better" way of installing remote start if you hook up the tach wire.
Brookef35
Apr 4, 2016 10:45 AM
ftrms
Audio / Security / Video
Feb 18, 2011 09:17 PM
ryaned380
Aug 17, 2010 07:40 PM
DCSportEJ1Civic
11
Mar 23, 2010 03:11 PM
