Neptune RTP -- H22A JDM basemap needed??
Hi, So... I obtained a NeptuneRTP.. very cool btw.. I need to track down a base map perferably something like identical to oem spec if that's possible as nothing is done to my engine.. I recently failed emissions and I believe its due to a ECT sensor being not connected right..
2%CO when it should be 1% 450HC when should be 220 ish..
Anyway
I was curious if there is a USDM basemap as the p13 code for jdm h22a's isnt compatible for some reason, so the question is how different are the base map codes for the us h22a1-a4?
I'm kinda not looking to modify the map at this time simply load on a stock map and watch sensor data on the screen and then start to tinker with it later.. Hope that makes sense.
--Aaron
Anyway
--Aaron
thirsk66
Feb 15, 2015 09:15 PM
