FS - SWAPPED 1990 Acura Integra GS (DA9)
SWAPPED 1990 Acura Integra GS (DA9) red in colour
I'm gonna list it at $3500 OBO, no trades.
the car is located in Edmonton Alberta
THE GOOD
B20B swap (1997 CR-V) 100,XXX on engine (done in 2007)
Complete conversion to ODB1 with Xenocron ECU conversion harness and P-75 ECU and re-pined odb1 dizzy
Kept the B18A1 low impedance Injectors - cleaned and tested in the last 2 months
Converted from auto to manual
Hydro LS tranny w/ Acura MTF changed less then 2 months ago
‘Innovative Mounts’ steel engine mounts with ‘Street Duro’ poly bushings and black ‘hammer tone’ powder coat
‘Innovative Mounts’ cable to hydro clutch actuator with Wilwood 5/8” master cylinder and custom hydraulic line
Consol mounted Aux fan switch
Consol mounted diagnostic switch (turn on to see codes, CEL will turn on solid to indicate codes when switch is off)
E-bay short throw shifter
E-bay intake piping, the old air inlet group has been removed.
GS-R seats front and rear. (Thanks Charlie)
Megan rear upper shock tower bar (will supply front but does not mount up becuase of ABS)
Fresh paint on front bumper (completely wet sanded, filled and painted bumper black, two coats primer and 3 coats black (done this summer)
The rear seats are removed but will be supplied with sale
A/C removed
Still has power steering
New fuel pump and filter in the last 2 months
New battery
New alternator with transferable 5 year warranty at Wilson’s Autotech (Southside)
Stock Integra wheels with all seasons not the wheels and tires in the pictures
Infinity Kappa series speakers with Pioneer MP3 deck
Remote starter/alarm w/ 1 LCD and 1 LED remotes, both are 3000’ 2-way I think
THE BAD
301,XXX KM on frame
Typical rust at rockers and wheel wells and some on the doors
Fasted Ľ mile ET 17.420 (it was my first and only time at street legals)
will add pictures later today.
out of town deposits can be made with paypal balance in cash or certified cheque only.
for pick-up only - if wanting to ship, buyer makes all arraingments.
Modified by ladyfriend at 8:43 AM 9/1/2008
Modified by ladyfriend at 7:23 AM 10/3/2008
THE GOOD
A/C removed
New battery
THE BAD
301,XXX KM on frame
cleanda6
May 3, 2010 08:53 PM
Free bump!!!
