Swap walkthrough for eg b18c1 swap
Ive been searching cant find any complete writeups for the 92-95 hatchback b18c1 swap, Was wondering if anyone out there has one bookmarked or anything for the EG b18c1 swap writeup.
there are many posts and write ups on this topic. Search harder next time. The FAQ's at the top of the forum is loaded with information.
Here is one of the most common:
http://www.c-speedracing.com/h...p.php
Thats a really good walkthrough, thanks, but im not worried about the bolting procedure, im more worried about the wiring and the ecu, I have a 93 eg6 and im worried about the whole ecu thing.
easiest thing to do is buy a usdm OBD-1 vtec harness say out of an EX coupe since they are common and then get the p72 gsr computer and its plug and play
If i buy the swap from HMO or IAS it should come with the harness, and ecu correct? Reason im a bit worried is that ive got an auto in this stock 93, i will be converting it to manual and i know the ecu's are different. Question is tho, if i get a obd2 engine and ecu am i screwed, sorry im a bit of a novice with this computer stuff, i can do anything carburated, just new to this ecu crap.
http://www.hmotorsonline.com/s...30009
this is what i plan on getting, do i need to make sure its obd2 or what if it is obd2 what are my options?
Modified by revlimitx04 at 12:34 AM 8/22/2008
you can get an obd2 motor, just wiring is slighly dirferent pretty simple though. you can use your auto harness. get an obd1 p72ecu or if your going hondata your P28 will be fine just takes 1 resistor to change it from auto to manual RP17-RP18
Man ant your like a honda god to me, You know of any wiring DYI's for obd2 harness conversions, also the engine comes with the wiring harness and ecu so is it pretty much plug and play? I dont think ill have to worry about the convo between auto to manual since it comes with the p78 or whatever, the GSR ecu.
Thanks for all the help guys, i know there is a ton of b18c1 thread titles, so i appreciate the confidence everyone has given me about the computer issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 »</TD></TR><TR><TD CLASS="quote">Thats a really good walkthrough, thanks, but im not worried about the bolting procedure, im more worried about the wiring and the ecu, I have a 93 eg6and im worried about the whole ecu thing.</TD></TR></TABLE>
aye stoooopid you got a EH2 not a fuccin EG6
stupid white people.
why you report me cuhz? im jus helpin you out mang
Modified by ayeCuhz at 11:31 PM 8/21/2008
Modified by HybridcivicLS-T at 1:40 AM 8/22/2008
Modified by HybridcivicLS-T at 1:41 AM 8/22/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ayeCuhz »</TD></TR><TR><TD CLASS="quote">
stupid white people.</TD></TR></TABLE>
uh what? reported.
uh what? reported.
Modified by HybridcivicLS-T at 1:41 AM 8/22/2008</TD></TR></TABLE>
completely unacceptable, your a newbie as well. I would really hate for you to be banned. please read the rules that type of behavior will not be tolerated and will cause and deserve an instant band.
Please don't start on Honda-tech in a bad way. Thanks
Ant
Ant
And i went outside to check the vin, ayecuz your right it is a EH but the only difference is JDM vs USDM, so basically an EG is a EH just not righthand drive. but thanks for clearing that up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 »</TD></TR><TR><TD CLASS="quote">Man ant your like a honda god to me, You know of any wiring DYI's for obd2 harness conversions, also the engine comes with the wiring harness and ecu so is it pretty much plug and play? I dont think ill have to worry about the convo between auto to manual since it comes with the p72 or whatever, the GSR ecu.
Thanks for all the help guys, i know there is a ton of b18c1 thread titles, so i appreciate the confidence everyone has given me about the computer issues</TD></TR></TABLE>
no way man am I no god, no where near. I just have experience in somethings I happen to be pretty good at solving dumb issues becuase i've been through it. I look for help whenever i can and learn as much as i can. If I feel that im that good I need to quit playing with hondas and do something different
check this wensite out
http://www.ff-squad.com you can learn a lot on there. from that site i did things that i had never done before by myself and they have cool music. Go to the Tech section
Rikaro
Jul 24, 2008 11:23 AM
streetcartuner
Jan 7, 2007 12:11 PM
