oil pan help...
Old Aug 20, 2008 | 06:28 PM
wesleywhite989's Avatar
Default oil pan help...
will a p72 oil pan(gsr oil pan) fit on my b18a1??
Old Aug 21, 2008 | 04:23 AM
Default Re: oil pan help... (wesleywhite989)
anyone????
Old Aug 21, 2008 | 05:19 AM
neardon's Avatar
I'm a Jackass
Part numbers are different but the oil pan gaskets are the same. So it will bolt up it just might be a different size. For future refrence http://www.acuraautomotiveparts.org
Old Aug 21, 2008 | 07:01 AM
92integraVTECgsr's Avatar
Default Re: oil pan help... (neardon)
it will fit, but it wont be accurate when checking your oil.
GSR oil pans are deeper to accommodate the girdle and longer oil pickup. LS oil pans aren't as deep.
Old Aug 21, 2008 | 10:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: oil pan help... (92integraVTECgsr)
Would the oil pickup still work okay then, because if it's deeper then the top of the oil will sit lower, if the same amount of oil is used. Seems like it would be easier to starve the pickup.
Old Aug 21, 2008 | 02:30 PM
Default Re: oil pan help... (PatrickGSR94)
well just a question cause i have an ls vtec but where the drain plug goes is stripped out and i have access to a gsr oil pan so just wondering if it would work but it doesnt really sound like its recommended
Old Aug 21, 2008 | 03:46 PM
so should i just go with the ls oil pan??
Old Aug 21, 2008 | 07:16 PM
t-splice.mn's Avatar
cant you just tap the pan you have and get a new drain plug?
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
hondaboy4life
Sep 29, 2006 08:01 AM
SlammedBlackGSR
Sep 13, 2006 09:36 AM
iTzKeviN
Jan 8, 2006 06:30 PM
