proper procedure to fix idle on a d16y8
Old Aug 20, 2008 | 06:01 PM
pjr710's Avatar
Default proper procedure to fix idle on a d16y8
i recently spun a bearing b/c my idle was so low that when my oil got hot i'd lose oil pressure.
i tried turning the screw when the car was on but it didnt do anything
so can somone tell me the proper procedure for adjusting idle using the screw?
i already cleaned my iacv btw
Old Aug 21, 2008 | 02:31 PM
pjr710's Avatar
Default Re: proper procedure to fix idle on a d16y8 (pjr710)
bump
Old Aug 22, 2008 | 05:01 PM
pjr710's Avatar
wow .. no one knows, hmm .. come on honda-tech
Old Aug 22, 2008 | 05:29 PM
nub's Avatar
nub
Get engine to operating temp., shut off, disconnect iacv, start engine, turn screw in to lower idle or out to raise, shut off, plug iacv back in, remove back up fuse to clear iacv code, replace fuse and start up, check idle speed
Old Aug 22, 2008 | 05:52 PM
pjr710's Avatar
Default Re: proper procedure to fix idle on a d16y8 (nub)
thanks, just what i was lookin for, where is the iacv fuse, drivers side or in the engine bay?
Old Aug 22, 2008 | 05:58 PM
nub's Avatar
nub
No fuse for the iacv, unplug the sensor itself. On the firewall side of the intake plenum
STi-Thrill
Oct 16, 2010 02:41 PM
jah.tien
Jul 14, 2010 10:37 AM
Mr. LS VTEC
Oct 25, 2006 05:43 AM
SLOAZZ95
Aug 13, 2004 09:34 AM
crx_88_si
11
Aug 5, 2004 07:28 AM
