car wont start
so a few days back my car stop working out out of nowhere..when i tried starting it up i relized i wasnt gettin spark..so i checked my spark plugs and they were dripping oil..so i replaced the gaskets and plugs..but the car still wont turn over..idk what to do from here..i replaced plugs wires and gaskets and still nothing..if any1 out there knows what the deal is please help..thank you
its the ignition barrell
my cars in my drive atm bout to get fixed.
its a common problem with the 4th gens.
shouldnt cost too much to fix
if you hold the key between the ignition and the other bit that starts the cd player ect, it should go.
i thought id fckd the electronics cuz my dash lights are a bit fruity, but nah
its a simple fix
xxxx
its a simple fix
xxxx
You plugs probably had oil on them because you are leaking oil through the
spark plug tube seals. Where did you check it for spark from?
Your no spark problem could be a number of things such as the ignition coil
itself, distributor, ignitor etc.
dan89crxsi
Feb 10, 2007 02:44 PM
