Shifter Bushiing question: LS block with b16 tranny, which to buy
Old Aug 20, 2008 | 01:08 PM
Convert's Avatar
Default Shifter Bushiing question: LS block with b16 tranny, which to buy
A little more in depth, i have a 2000 GS with a hydro to cable conversion and a b16 tranny. I need some new shifter bushings and i want to make sure that im purchasing the right ones.
Any suggestions?
thanks!
Old Aug 20, 2008 | 01:29 PM
Circusraven's Avatar
Default Re: Shifter Bushiing question: LS block with b16 tranny, which to buy (Convert)
What did your linkage come out of? You'll probably be good with a 90-93 integra kit from energy suspension if it's cable B16 tranny.
Old Aug 20, 2008 | 01:55 PM
Convert's Avatar
Default Re: Shifter Bushiing question: LS block with b16 tranny, which to buy (Circusraven)
dunno man.got it with the swap done already.
Old Aug 20, 2008 | 02:40 PM
Convert's Avatar
just checked, its a ys1 tranny. hope that helps someone
Old Aug 20, 2008 | 03:57 PM
Convert's Avatar
por favor?
Old Aug 20, 2008 | 04:35 PM
YS1 is off a 92-93 GSR if it's a USDM YS1. So the 90-93 shifter kit should work.
This is the linkage off a 92 DA.
The bushings only go on the linkage bar that's on top, you can see the round rubber one on the right and the long square one on the left. Plus if you check ebay or something, the kits are are actually sold as "90-01" for tegs, so you're good to go no matter what.
Old Aug 20, 2008 | 05:04 PM
BlueIntegraBoy's Avatar
B-series Shifter Bushing Kit.
Old Aug 20, 2008 | 05:10 PM
Convert's Avatar
Default Re: Shifter Bushiing question: LS block with b16 tranny, which to buy (BlueIntegraBoy)
Thanks for the help guys! I can put it in gear and the damn thing still flops like its out of gear. really annoying!
Carlos 88CRXSi
Feb 14, 2011 12:54 PM
AllMotorDB2
Sep 19, 2006 04:14 PM
IloveAPC
Oct 3, 2004 09:49 PM
itsallmotor
Feb 6, 2004 05:58 PM
riot
Apr 6, 2002 07:27 AM
