96 Integra LS starts up then cuts off after letting go of key
Old Aug 20, 2008 | 12:15 PM
kintaro's Avatar
Default 96 Integra LS starts up then cuts off after letting go of key
Did a couple of searches for this problem. Changed out the Main Relay switch, the distributor cap and the rotor button. I try to start the car and it starts but as soon as I let go of the key, it dies.
One possible solution said to listen for the clicks of the Main relay. Well, b4 I changed the main relay switch, i didn't hear any clicks and now even after I changed the main relay switch, I still don't hear any clicks.
If I hold the key in the start position, it stays running. Once I let go, the car dies.
Help. Already spent over $100.00 and no solution yet.
Anyone else have any ideas?
Thanks,
kintaro
Old Aug 20, 2008 | 12:44 PM
cetcivic's Avatar
no one wants to hear the truth
Default Re: 96 Integra LS starts up then cuts off after letting go of key (kintaro)
something may just be loose.this happened to me recently,it was a loose plug from the ignition switch.these are located underdash one in the fuse box the other next to it..good luck
Old Aug 20, 2008 | 01:40 PM
EARLdaSQUIRREL's Avatar
official honda whore
sounds like the ignition wiring from the ignition to the fuse box
Old Aug 20, 2008 | 02:48 PM
mdb63040's Avatar
i had the same problem, it ended up being the clock spring in the steering column.
Old Aug 22, 2008 | 05:34 AM
kintaro's Avatar
Default Re: 96 Integra LS starts up then cuts off after letting go of key (mdb63040)
Did you change the clock spring yourself? If so, do you have a write up? If not, how much did it cost to fix?
I really need a write up to do it myself. I would have to get it towed if someone else does it.
I ask about this because someone came by yesterday and took a look at it and said the same thing. That it is the spring.
But thanks for everyone else's input.
Thanks,
kintaro
Modified by kintaro at 10:55 AM 8/22/2008
Old Aug 22, 2008 | 03:31 PM
lowtegsr's Avatar
just had this same problem last week, when u go to start ur car. right after it fires up slowly let ur key come back and it should stay running. this means ur ignition switch is out, u can buy them from partsgeek.com for $46 after shipping. there not hard at all to replace.
D7KWagon
Aug 28, 2014 12:20 PM
JusAccord
Mar 29, 2012 06:38 PM
FliPCRuSH022
Jul 14, 2009 05:21 PM
skazoo
Jul 11, 2009 12:09 PM
