metal rattling noise in engine when i drive
Old Aug 20, 2008 | 06:09 AM
hkboy87's Avatar
Default metal rattling noise in engine when i drive
Around 3k rpm when I accelerate moderately I hear this sound that sounds like a small piece of metal in rattling in a tin can. All the other rpms are fine except when it hits like 3k to like 3.5k there is this noise. Whats the problerm?
Car is a d16y7 stock with auto tranny.
Old Aug 20, 2008 | 06:31 AM
HitF8's Avatar
Default Re: metal rattling noise in engine when i drive (hkboy87)
check heat sheilds
JoeDel's Avatar
try checking your heat shield on your exhaust, my wifes suby does it all the time when stopped
Old Aug 20, 2008 | 06:37 AM
hkboy87's Avatar
oh it might be that...to clarify more, it sounds like a pinging noise on a piece of metal
Old Aug 20, 2008 | 06:41 AM
craigaria's Avatar
Default Re: (hkboy87)
better check your timing too, could be spark knock
Old Aug 20, 2008 | 06:47 AM
OMGWTFBBQ!'s Avatar
+1 on spark knock.
Old Aug 20, 2008 | 06:52 AM
HeikDiesel's Avatar
Default Re: (OMGWTFBBQ!)
Spark knock?
Old Aug 20, 2008 | 06:54 AM
craigaria's Avatar
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">Spark knock?</TD></TR></TABLE>
detonation
Old Aug 20, 2008 | 06:57 AM
HeikDiesel's Avatar
Default Re: (craigaria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by craigaria &raquo;</TD></TR><TR><TD CLASS="quote">
detonation</TD></TR></TABLE>
Never heard it called that. Guess I better brush up on my lingo
Old Aug 20, 2008 | 08:02 AM
Irritated_Onion's Avatar
Check it detonation. It's how Diesel engines work.
Old Aug 20, 2008 | 08:12 AM
sageuvagony's Avatar
Default Re: (Irritated_Onion)
I had the same problem at that exact RPM. It was the heat shield for my CAT that was going bad so I just unbolted it and took it off, and no more noise. Same thing happened to my Explorer. Muffler shop just ripped the heat shield off of the cat and rattle went away.
Old Aug 20, 2008 | 08:25 AM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irritated_Onion &raquo;</TD></TR><TR><TD CLASS="quote">Check it detonation. It's how Diesel engines work. </TD></TR></TABLE>
Kinda. Detonation is an un-contolled burn. Diesel engines run off a precise injection
Old Aug 20, 2008 | 08:30 AM
JoeDel's Avatar
Default Re: (sageuvagony)
i would try to fix it before you pull it off of there my step father pulled his off on his old caprice and the floor caught fire... funny as hell to watch but im not taking any chances
Old Aug 20, 2008 | 08:35 AM
B16AGUY's Avatar
I agree, it sounds like a heat shield to me.
I had same prob @ same RPM's on my old hatch.
It's annoying as heck but nothing to worry about.
I would also rule out the detonation theory though, just to be safe.
Another thing, when I installed my new header the O2 sensor came partially loose 24 hrs later. It made the same low rpm rattle. If your shields are good, and your sure it's not detonation, make sure the O2's are tight.
Note: the loose O2 is a freak thing so I doubt it's that.
Old Aug 20, 2008 | 08:39 AM
Default Re: (JoeDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeDel &raquo;</TD></TR><TR><TD CLASS="quote">i would try to fix it before you pull it off of there my step father pulled his off on his old caprice and the floor caught fire... funny as hell to watch but im not taking any chances</TD></TR></TABLE>
Old Aug 20, 2008 | 10:33 AM
hondroid015183's Avatar
Its pretty bad when they have heat shield repair on the service menu at the honda dealership.
Old Aug 20, 2008 | 11:02 AM
B16SolMan's Avatar
New User
I hate heathshield, and double piped exhaust pipes!
Old Aug 20, 2008 | 11:36 AM
hkboy87's Avatar
i heard if you take the headshield out, it might melt ur ac line
Old Aug 20, 2008 | 11:39 AM
timtech's Avatar
Could be the bottom engine mount at the timing belt end loose and rattling against the chassis - I had this problem when the garage changed the timing belt and forgot to tighten the nuts up after...
Old Aug 20, 2008 | 11:41 AM
Frickr's Avatar
Default Re: (B16SolMan)
just get some bailing wire and wrap a piece around the cat and sheild, twist it down with a plyers and no more rattles. ive seen whole exhaust systems held together by this stuff guess that makes me a north dakotan
Old Aug 20, 2008 | 12:02 PM
drSquish's Avatar
Check your catalytic converter, muffler(s), and/or silencer(s). A piece or pieces of the insulation in one or more of those devices could be rattling around with the exhaust flow. I've had two vehicles with this problem.
Answer = Pass emissions and find a test pipe
Old Aug 20, 2008 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkboy87 &raquo;</TD></TR><TR><TD CLASS="quote">i heard if you take the headshield out, it might melt ur ac line</TD></TR></TABLE>
My A/C lines are no where near my cat converters. My cat converters are under my car. The thing I DO worry about is a stray bag on the road getting stuck to my cat and getting a nasty melting plastic smell for days or weeks. Happened to my girlfriend's old 2001 Malibu. And that's WITH the shield on.
Old Aug 20, 2008 | 06:11 PM
B16AGUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">
My A/C lines are no where near my cat converters. My cat converters are under my car. The thing I DO worry about is a stray bag on the road getting stuck to my cat and getting a nasty melting plastic smell for days or weeks. Happened to my girlfriend's old 2001 Malibu. And that's WITH the shield on. </TD></TR></TABLE>
Same thing happenned to me on my 97 hatch.
The cat on those is attached to the exhaust mani on the bottom front of the motor though, not under the car like say an EM1.
Old Aug 20, 2008 | 06:39 PM
fryman's Avatar
Your talking about on the headers right?
CRX-CHACE
Sep 15, 2013 07:45 PM
1SlowSi
May 30, 2008 04:25 AM
whitelightning
Mar 29, 2007 12:58 PM
HCJDM1
Aug 29, 2006 10:42 AM
chue_li
Mar 22, 2005 10:48 AM
