Need Help with EF Rear Disc Brake Swap
Old Aug 20, 2008 | 12:51 AM
RB_EJ8's Avatar
Default Need Help with EF Rear Disc Brake Swap
I swapped brakes from a 90-93 DA. Do I also need to swap the master cylinder, booster, and 40/40 proportion valve from the Integra?
Maybe thats why the brakes feel spongy
Modified by RB_EJ8 at 2:07 PM 8/21/2008
Old Aug 20, 2008 | 02:59 AM
juandaman's Avatar
Default Re: Need Help with EF Rear Disc Brake Swap (RB_EJ8)
Yes you need to all those things to comply with the new calipers!
Old Aug 20, 2008 | 03:02 AM
rbwdriven's Avatar
did you bleed the brakes?
Old Aug 20, 2008 | 04:22 AM
blkef4dr's Avatar
I HAVE 2000 SI DISC BRAKES ON MY EF 4DR
ALL I REPLACED WAS THE 40/40 PROPORTION VALVE
AN BLEED BRAKES
Old Aug 20, 2008 | 07:48 AM
RB_EJ8's Avatar
Default Re: (rbwdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbwdriven &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed the brakes?</TD></TR></TABLE>
I've bleeded them twice and they still feel spongy!
Old Aug 20, 2008 | 08:12 AM
EL Vap133's Avatar
Default Re: (RB_EJ8)
Sometimes you need to bleed them quite a few times to get it right. Did you bench bleed the MC? Was the MC and BB new, used, or rebuilt?
Old Aug 20, 2008 | 08:30 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: Need Help with EF Rear Disc Brake Swap (blkef4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkef4dr &raquo;</TD></TR><TR><TD CLASS="quote">I HAVE 2000 SI DISC BRAKES ON MY EF 4DR
AN BLEED BRAKES </TD></TR></TABLE>
*motions towards caps lock button*
was your sedan an EX? If so I'd say thats all you need. But the biggest difference for me came in going from 13/16" to 15/16" BMC.
Old Aug 20, 2008 | 09:05 AM
nickrps's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes you need to bleed them quite a few times to get it right. Did you bench bleed the MC? Was the MC and BB new, used, or rebuilt? </TD></TR></TABLE>
x2. I would mos def recommend the MC upgrade, but the prop valve is not a must. And if you don't beleive me, call Brian at Fastbrakes. He told me not to even bother putting in the 4040, but I did it anyways.
Re-bleed the brakes (correctly) and see where you are at. Even with the rear upgrade, your brakes should not be squishy...hell, I ran disc brakes with my hf mc/booster for a couple years on track before upgrading once I got faster.
Old Aug 22, 2008 | 01:18 AM
blkef4dr's Avatar
Default Re: (nickrps)
ya its is a EX
Old Aug 22, 2008 | 03:27 AM
aztecracer1's Avatar
Default Re: (blkef4dr)
Took everything off of a 94 teg and the proportion valve was a 30/30, also the brake cables did not fit had to use Da cables, and the ef upper arm.
Old Aug 24, 2008 | 10:41 PM
RB_EJ8's Avatar
Okay! So I've replaced it with 4040 prop valve from an Integra, bleed the brakes twice and Its still spongy.
When the ignitions off, the brakes feel firm Soon as I crank the motor the pedal feels spongy
I'm going to try Bench Bleeding next! Master Cylinder 15/16" is Original and so is the Brake Booster
classic69
28
Jan 8, 2025 08:12 AM
sleephondsleep
Apr 1, 2008 08:01 PM
Jstuneshop
11
Mar 19, 2006 02:35 PM
Built Beast
Jan 23, 2004 10:58 AM
ef9one6
18
Aug 7, 2003 10:28 AM
