need so help with my crx
Old Aug 20, 2008 | 12:23 AM
sLAg's Avatar
Default need some serious help with my crx
ok heres the thing the car turns on it works for a while i.e. ill drive it around normal and wen i stop turn it off and try to turn it on ususally it turns on but it starts turning off and wen i give it gas it doesnt work just turns right off and wen i try to turn it on again it wont turn on it wants to cuz u hear it the tch tch tch but no vrooommmmmm even if i give it gas or kick start it,
ive taken the car to 2 diff shops and they cant find anything wrong with it, they say that it works fine it didnt give them problems watsoever and didnt turn off on them i askd if the can check c if a short, batt, alternator, and everything is fine but i noe theres something cuz it seems like it just happens to mee i need help to fix thiss
asap
ps: its all stock no mods at all i hate my life
<center>
</center>
Old Aug 20, 2008 | 05:43 AM
scottmog's Avatar
Default Re: need some serious help with my crx (sLAg)
you want to know if ur main relay and fuel pump are working? its very ez and u dont need to even get your hands dirty.
1. sit in the driver seat
2. turn the key to position 2 (not engine, but a/c and stereo on)
3. u will hear a click (main relay) and half second hum (fuel pump) while the engine light is on.
if u dont hear either one of those, there is ur problem.
Old Aug 20, 2008 | 08:00 AM
B16-CRX's Avatar
Check main relay. They go bad when they are hot. Just do a search.
Old Aug 20, 2008 | 08:14 AM
IndySporty's Avatar
Default Re: (B16-CRX)
The relay is located right above the hood release inside the dash it's a black or brown box held in with a 10MM bolt. Go to the junkyard and get a few of them and rotate them out every time the car won't start. Either that or you can pop the lid off yours and re-solder the connections and it will be like new again. I keep a re-soldered one on hand just for these occasions.
Old Aug 22, 2008 | 07:30 AM
slicedbreadno2's Avatar
Default Re: (IndySporty)
Good luck hopefully it isn't the main relay.
Old Aug 22, 2008 | 08:11 AM
jlicrx's Avatar
could also be the igniter
FrozenDoughnut
May 24, 2009 04:31 PM
anth6ny
Feb 28, 2008 06:32 AM
skater5067
18
Jun 26, 2005 04:24 PM
Ideal
Nov 6, 2002 09:47 AM
awall
May 16, 2002 10:37 AM
