I have a question on which axle to use
Hey everybody I am in need of help. I am doin the 5 lug conversion on my car which is a 98 integra ls.the back is done already but my question is which axles I use bc I have a gsr tranny and ITR lsd and the 5 lug conversion.But I heard the jdm and usdm uses different axles. Usdm is 32mm and jdm 36mm how can I tell if its the jdm one or usdm.please someone help me
Take your stock axle and see if it fits in the hub. If it does, then you're set, you can use stock axles. If the hub is too big for your stock axles, you have the JDM 5-lug. Then you will need Prelude, Accord, or CRV outer joints on your stock axles.
Hey buddy thanks for the info I found the prelude outer joints on ebay justed wanted to make sure these r items I need thanks again
http://m.ebay.com/bid/viewitem...6x136
