da wont start
Old Aug 19, 2008 | 04:28 PM
PatrickFrantz's Avatar
Default da wont start
ok ive searched an cannot seem to find anything on this so here goes!
i have a 1990 ancura integra that when i turn the key on the fuel pump dosent engage but the car turns over an gets spark jus no sign of the fuel pump kicking on!
does anyone know what might cause this problem???
Old Aug 19, 2008 | 05:04 PM
Default Re: da wont start (PatrickFrantz)
ttt someone please help
Old Aug 19, 2008 | 10:03 PM
help me so i can sell my car!!!
Old Aug 20, 2008 | 04:51 AM
The G2 Racer's Avatar
Most likely the main fuel relay is bad.
Common issue on DAs, EFs and early EGs too.
Bout 70 bones from the dealer.
Old Aug 20, 2008 | 08:29 AM
dadriver's Avatar
Default Re: da wont start (The G2 Racer)
dose the check engine light flash when you trun on the car it should turn on with the fuel pump and tune off with the fuel pump?
Old Aug 20, 2008 | 09:20 AM
Default Re: da wont start (dadriver)
i thought it might be the fuel relay but wasnt sure.
an yes the check engine light comes on when i turn the key then it shuts off like it should be the fuel pump dosent kick on
Old Aug 20, 2008 | 12:52 PM
tttttttttt
Old Aug 20, 2008 | 12:56 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Most likely the main relay, had the same problem in my EJ1, Swapped the Main relay and now it works fine. Maybe try to use a buddys relay or get one from the junkyard and see what happens.
Old Aug 20, 2008 | 01:36 PM
Default Re: da wont start (PhantoM.DA)
ok cause i jus changed the fuel relay an nothing happened so i must be the main relay!!!
Old Aug 21, 2008 | 05:53 AM
i changed the main relay today an it started right up!!! thanks guys for all the help
jerome^galon
Jan 4, 2012 07:03 PM
allmotor2.1
Nov 24, 2007 04:52 AM
Lsweez
Jun 28, 2007 10:08 PM
ROK801
Oct 31, 2005 07:28 AM
