88 civic lx 99 jdm b16a swap
how difficult would it be to do this swap if i have the full harness and ecu for the motor. i know i'll need mounts from hasport but what else is needed to complete this swap. i also was wandering if the dash harness plug on the car will match the plug on the b16 harness.
search and ye will find. check the 'archived' content.
i believe you will need a transmission and DA axles. i think 99 wiring won't match up to the dash. ecu will be ok but you'll need something for the speedometer. this is off the top of my head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverbullet9626 »</TD></TR><TR><TD CLASS="quote">I can't use the b16 tranny?</TD></TR></TABLE> No you can, I think he was meaning you can't use a D series trans, as you stated in your first post you have the motor.
Hit the FAQs as he said all the info is there and ask if you get stuck
duh my bad should have mentioned that i have the full motor already swapped into a 96 dx coupe but having emissions issues
jr13music
Feb 6, 2014 04:42 PM
RBNightMare
Dec 3, 2007 08:03 AM
