D16/ZC oil pan baffles?
Just wondering what some of you guys use for oil pan baffles, or if there is one OEM pan thats better than others. I have a CRX with a DOHC ZC, and would rather not spend $380 on a Moroso pan if I don't need to.
Kevin at CrankScrapers.com referenced me to the Boylans, that road race a D16. He remembered that they use baffles on that engine, and had a lot of information on what pan to use, etc. I believe they're from Florida, anyone know how to get ahold of them?
he's talking about the twin cam d-series.
one of my teammates is building one of those (not a zc, but a twin cam d-series) and is gonna use the morosso pan. i'm using one on my b16 but i tink most people that use baffled pans are doing so for extra protection. not so much because of an oil pressure drop.
Yes, I'm running a DOHC ZC. Sorry for the confusion.
I have a friend that runs a D16Z6 in a CRX, and has had low oil pressure once during a race with the factory pan. He immediately bought a Moroso pan and hasn't had any problems since... I'm just trying to weigh my options since I need to take off my pan soon anyway.
What would be the best D series pan to run, and that would fit on a DOHC ZC/D16A6?
A stock pan. Use a Y8 pan (other things needed to make it work) but be afraid of hitting it as its cast aluminum.
I'm using a 5.5 qt pan for a Z6 on a customer D16A1 (similar to the DOHC ZC). One of the benefits of it is more clearance in the header tunnel so you can run a custom 4-1 with a merge collector and still have great ground clearance.
15 hours on track and for the most part no issues. I ran VIR north last summer and at the top of the roller coaster I would get a low pressure light that would blink on just long enough to catch my eye. Threw an extra half quart in there and havn't seen the light since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">i have hours and hours of logging and the d16z6 has no oil pressure drops, no need for a baffled pan
What that guy said.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF »</TD></TR><TR><TD CLASS="quote">he's talking about the twin cam d-series.
I second the notion of making your own baffles if you're in a pinch and want some immediate peace of mind.
For one, I have no access to sheet metal or anything to cut it with... A kit like Fastline's B series baffle kit would be perfect, but I can't find one for a D series. I guess I need to snoop around for someone that can fab up some baffles...
Voodooboy, you're running the stock ZC pan, correct?
iplaybass
Jan 22, 2004 09:14 PM
Waiting on a few more parts until I assemble the engine.
