Keeping A/c in Ef with a B series swap.
So I found a couple threads but nothing that helps me with the DIY bracket.
I heard about a hcp bracket. But all the links I found are bad to their site. I see talk about a hasport one, and somone mentioned the p54 bracket but thats for the eg.
So what can I use to keep a/c in my sedan when I do my swap.
I have it done it yet...
Thats why im asking...
Because when I searched I read alot of mixed info.
And my car is a 91 ex civic sedan. Im not changing the radiator or the fans at this time. Just want to keep my a/c.
the problem is with the radiator. since the b series motors are bigger than the d's, there isnt that much clearance for an ac compressor.
ask around and you'll find out people that have ac in a swapped out car have a half radiator. if you get a half or maybe even a slim,(full size but slimmer) then you should be good with the stock ac bracket for whatever motor your putting in.
i know innovative makes one that will let you retain your complete stock ac setup. ive also heard of ppl using their stock bracket and only using one bolt to hold it on. and ive heard ppl modifing b series motor ac brackets to work.
I was thinking about doing the same thing and addding AC to my B18. I was looking at the P54 Del Sol bracket and saw that the B20 bracket also supports a D series AC compressor an dis about half the price.
https://honda-tech.com/zerothread?id=1301513
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alupso »</TD></TR><TR><TD CLASS="quote">I was thinking about doing the same thing and addding AC to my B18. I was looking at the P54 Del Sol bracket and saw that the B20 bracket also supports a D series AC compressor an dis about half the price.
That is for a EG dude... We are doing EF here...
Ive read about 3 threads I found that, that bracket will not work!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16-CRX »</TD></TR><TR><TD CLASS="quote">I used the innovative one and it worked fine. Just make sure you change all your o rings if you are converting to r134 and replace the drier.</TD></TR></TABLE>
Did you use a b series compresor or keep the stock d series one?
i used an ls bracket and made an adapter so i could use my stock compressor. but i had to get an aftermarket crossmember to clear the compressor and get a little longer belt. the fan shroud makes it an absolute bitch to get the hoses on too. hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mra4886 »</TD></TR><TR><TD CLASS="quote">try hitting up b16crxt i was viewing his build thread and he used a b series bracket with a half sized radiator and hooked up a half sized condensor.</TD></TR></TABLE>
actually I'm using the stock condenser with the oem crossmember. I'm using the stock d series a/c compressor with a b series bracket. I cut off the arm for the torque mount, cut a couple pieces of plate steel and welded them to the bracket, then tapped holes in them.
and here is a more detailed writeup of how to do it, although I didnt know about this link until after I did mine.
http://www.geocities.com/crxls18/ACmod.html
Modified by B16CRXT at 8:57 PM 8/19/2008
well i sugjest that u just keep it i off thats me,on all of my cars i take off the power steering and ac pumps and thers a big diffrence on gas and hp gains
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honditacvcc »</TD></TR><TR><TD CLASS="quote">well i sugjest that u just keep it i off thats me,on all of my cars i take off the power steering and ac pumps and thers a big diffrence on gas and hp gains</TD></TR></TABLE>
This isnt my race car this is my daily driver... the track car is a different story.
in my ef the stock b18 bracket worked... but the AC lines would have had to been custom made because of the header i have so i just took the AC out completely
Here is the bracket from Innovative which allows you to keep your stock setup
http://www.innovativemounts.co...59180
PM me for a price
PM me for a price
