Somethings Wrong With My Ls PLZ Help
Old Aug 19, 2008 | 12:13 AM
LsTegDriver's Avatar
Default Somethings Wrong With My Ls PLZ Help
I Drive A 1996 Integra LS .... So Heres The Story
K I Was Driving Okay And SHifting Perfectly
Till I Parked My Car And LEft For Awhile...
I Came Back To Start It And It Wouldnt Go Into Gear
Turned Tha Car On And Off But It WOuldnt Go In
So I Turned It Off Slip The Car Into First Held Clutch Down
And Started It... IT TOOK OFF WITH MY FOOT ALL THA WAY DOWN ON CLUTCH
Does Anyone Know Whats Going On??
PLEASE HELP!!! I NEED TO KNOW WHATS GOING ON WITH IT
And It Smokes White But Smells Like Gas NOt Sure What That Is Either
But Doenst Lag So Its Not Head Gasket Piston Rings MAybe??
Old Aug 19, 2008 | 12:52 AM
northemt88's Avatar
check the hydrolic fluid for the tranny, did the pedal feel wierd loose, tight ?
Old Aug 19, 2008 | 05:51 AM
be18see1's Avatar
Default Re: (northemt88)
how old is the clutch? what is the fluid level in the reservoir? these are things that will help you and anyone else figure out the problem.
Old Aug 28, 2008 | 02:40 PM
Default Re: (be18see1)
yeah i had the problem fix thnx for help
it was the fluids
Old Aug 28, 2008 | 07:13 PM
tegra2G's Avatar
Default Re: (LsTegDriver)
If you have a leak find it unless you already have done so.
Fl1pkidd
Apr 6, 2007 04:16 PM
irideslammed5021
Mar 20, 2007 05:50 PM
ek9800
12
Jun 5, 2005 12:41 PM
