HELP
Old Apr 6, 2007 | 12:16 PM
Fl1pkidd's Avatar
Default HELP
Went to drive my car today, then realized while i was driving I couldnt put my car in gear ?!?! wuts wrong??
Old Apr 6, 2007 | 12:40 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP (Fl1pkidd)
Can you do it if the engine is off? Your clutch may not be fully disengaging.
Old Apr 6, 2007 | 12:50 PM
Fl1pkidd's Avatar
when the car is off i put it in neutral i think i had this same problem befor when my brake fluid ran out, last time it was the slave cylinder
Old Apr 6, 2007 | 04:06 PM
VTEC_PRODUCTION's Avatar
Default Re: (Fl1pkidd)
my car does this too once in awhile in a stop go situation at a stop sign or light...what is the dealio?
Old Apr 6, 2007 | 04:16 PM
DC4 Dave's Avatar
I had this issue on my '94 LS - seemed it didn't want to willingly engage the next gear, and felt a lot like I wasn't fully-disengaging the clutch.
I bled the clutch system using fresh fluid, and it feels like a factory clutch again.
I'm not saying that's the end-all solution, however it worked for me, and assuming you are having a similar version of my problem, it's the solution that fixed my car. Hope that helps.
duyfash0
Mar 20, 2010 11:28 AM
boostmee
Feb 7, 2008 04:12 AM
civicandr6
Mar 16, 2007 07:18 PM
nota-eg
May 28, 2006 09:29 PM
40oztoFreedom
Jun 3, 2004 11:40 AM
