Injectors not getting signal
i tested my injector clips with a noid light and there is no signal to them. What is wrong? I switched the ecu, could anything in the dizzy be wrong? Is there and injector driver?
Did you switch the ECU with another one because you thought that the original ECU wasn't working? The distributor has nothing to do with the injectors... they are controlled/powered by the ECU.
the injectors get a constant supply of 12+ volts. the ecu supplies the ground to complete the circuit. the distibutor does provide a signal for the fuel injection sequence.
Matthewhughes
29
Aug 5, 2014 03:18 PM
crxmadness
15
Jun 11, 2014 06:38 PM
averyvm
Engine Management and Tuning
Aug 22, 2013 11:02 AM
