Automatic Gauge Cluster
Old Jul 23, 2002 | 12:09 PM
Hawd's Avatar
Default Automatic Gauge Cluster
I have a 90 dx 5spd and I know some guy that has a guage cluster from an automatic 90 civic and it has a tach. Will it still work in my car? The only problem I see is that it has PRND in between the temp and fuel gauges, i prolly can swap them out or some ****.
Old Jul 23, 2002 | 03:32 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Automatic Gauge Cluster (Hawd)
i'm sure it will work.
i've done the opposite, used a manual cluster in an auto.
not all the plugs match up exactly...but plug in what you can, that's what i did and it worked perfectly like it should.
good luck.
Old Jul 23, 2002 | 03:35 PM
NikoZai's Avatar
Default Re: Automatic Gauge Cluster (two.oh)
oh go to the damn junkyard, theres plenty
Old Jul 23, 2002 | 04:22 PM
No More Civic's Avatar
Default Re: Automatic Gauge Cluster (NikoZai)
It will work. I was using a guage cluster from a 91 sedan auto with a tach in my 90 DX hatchback. Since then I found one for a 5-speed. All I did was plug in the wires, with no modifications at all. And it worked perfectly. I did however swap my speedometer into the newer one, it's alot easier to get the correct milage that way.
Old Jul 23, 2002 | 05:22 PM
Hawd's Avatar
Default Re: Automatic Gauge Cluster (SlowCivicDX)
thx for the help guys.
Old Jul 24, 2002 | 11:52 AM
xci_ed6's Avatar
I need a tach IM me if you have one please!
-Dustin
Anacrusis
Nov 15, 2009 06:16 AM
StupidSlowRSX
39
Aug 14, 2007 01:24 PM
powerslave
10
Sep 28, 2006 03:31 PM
CrxSi707
Mar 24, 2003 01:21 PM
serious
Apr 14, 2002 10:39 AM
