no spark n no fuel
Old Aug 18, 2008 | 06:40 PM
just another ef's Avatar
Default no spark n no fuel
hey i need help and i dont know wat to do.
i have a 1990 hatch si and it was runing and just died on me through washoe and now it wont start at all. its not geting fuel or spark but it turns over and i have no clue wat it is i changed the main relay and that wasnt it and the motor is good and the battier is good any ideas
Old Aug 18, 2008 | 09:03 PM
scottmog's Avatar
Default Re: no spark n no fuel (just another ef)
first of wtf is a washoe?
also, when u turn the key to position 2, do u heard a hum while the check engine light is on?
if u dont: change the fuel pump
if u do: describe more
Old Aug 19, 2008 | 10:11 AM
i dont heard it at all but would that make it not spark aswell
Old Aug 19, 2008 | 10:29 AM
abnaasefmb's Avatar
Default Re: (just another ef)
There is a camshaft position sensor in your distributor, if it takes a ****, you will not get spark and the fuel injectors will not fire. So I would look into that first, since you say everything was fine and it just stopped. Swap out a friends dizzy and see if that solves the problem, be sure to set the timing when you do finally put a new dizzy on.
Old Aug 19, 2008 | 01:43 PM
i did try one for another car. and the same thing. look i changrs out the main relay droped the tank and the fuel pump is good all the relays and fuses r good i changed out ecus and nothing so idk
Draiga1988
Oct 24, 2010 07:20 PM
youknowwhoibee
68
Dec 3, 2007 06:24 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
temp
15
Jul 6, 2004 08:07 PM
Circuit8
Nov 26, 2001 03:14 PM
