Suspension & Brakes Theory, alignment, spring rates....
Possible theory: Rsx rear tophat could be used as an extended tophat for a civic/integra
Old Aug 18, 2008 | 05:01 PM
EJ8chu's Avatar
Default Possible theory: Rsx rear tophat could be used as an extended tophat for a civic/integra
This could be a great idea, or i might just have my idea shut down. Who knows.
I recently was flipping through one of my old Honda tuning magazines. Towards the back, there was a simple write up on installing springs on a rsx. After glancing at some of the pictures, i noticed the rsx rear top hat resembled the height and had some of the same characteristics as my DIY extended top hats.
Let me follow up by saying, that in no way, do i have any proof that this could/will work. I saw a resemblance in the two and it got me thinking if it would be possible.
If anyone could get some measurements of the distance between the two bolt heads and the diameter of where the top hat would pass through the body is, that would be great. Ill measure my civic ones and go from there. Please leave some input/ or just fry the hell out of me
Old Aug 18, 2008 | 05:05 PM
EJ8chu's Avatar
Default Re: Possible theory: Rsx rear tophat could be used as an extended tophat for a civic/integra (EJ8chu
parts diagram of said top hats:
http://www.acuraoemparts.com/d...ch=no
Old Sep 6, 2008 | 04:55 PM
GReatEDDY's Avatar
ever try this?
Old Sep 6, 2008 | 05:52 PM
EJ8chu's Avatar
I'd like to but i do not have access to some rsx tophats.
Old Sep 6, 2008 | 10:35 PM
Tyson's Avatar
Default Re: (EJ8chu)
no, totally different dimensions. wont come close to fitting.
i thought of this years ago.
Old Sep 7, 2008 | 05:59 AM
EJ8chu's Avatar
Not trying to challenge you, but whats the main reason it wouldn't work? just curious
Old Sep 7, 2008 | 09:19 AM
Tyson's Avatar
first, the diameter of the middle portion is way too big, and the distance from center to center of the bolt studs are too big.
cant work.
Old Jan 28, 2009 | 06:25 PM
Natural Aspirations's Avatar
Default RSX Top Hats
I have seen this covered before with no answer to the question, and unable to find the thread.
For a low cost OEM extended top hat for lowered cars, does anyone know if the RSX rear top hats will fit other generations cars?
#9 52675-S6M-801 BASE, RR. SHOCK ABSORBER MOUNTING 2005 RSX 22.82
Old Jan 28, 2009 | 06:49 PM
xd69's Avatar
Default Re: RSX Top Hats
No:
https://honda-tech.com/forums/showthread.php?t=2368761
Old Jan 29, 2009 | 05:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Threads merged.
theineffable
Honda Civic (2001 - 2005)
20
Feb 14, 2013 07:33 PM
RacingPretty[S]
Dec 10, 2012 11:18 PM
polo609
18
Jan 13, 2008 02:55 PM
S1ERRA
Aug 2, 2003 01:36 PM
SPiFF
13
Aug 10, 2001 12:22 PM
