62405A-2 in a B20
Old Aug 18, 2008 | 02:04 PM
CRXSiR71777's Avatar
Default 62405A-2 in a B20
I'm heading to the dyno this weekend and I'm looking for some insight on cam timing for my 62405A-2s. I know every engine is a little different but I was hoping someone could give me some direction to work toward to dial things in.
Current set up is as follows:
B20 bottom end w/ OE rods with ARP bolts
Wiseco 12:5:1 Pistons - P8R head - Ported and polished - Head shaved to min
Crower 62405A-2 cams, Crane Springs and Ti Retainers
BLOX Intake Manifold - 70mm Throttle Body, fuel pressure reg, 4-1 header with 2.5" collector and 2.75" exhaust to the rear
Full Accel DFI Fuel Management - Including Wide Band O2, Dual Sync Distributor, 300+ ignition system
Any insight would be great. Cams set straight up made 200 whp even, so I'm hoping for a bit more.
TIA!
Old Aug 25, 2008 | 07:00 AM
Default Re: 62405A-2 in a B20 (CRXSiR71777)
Any input would be greatly appreciated.
Old Aug 25, 2008 | 09:33 AM
kp's Avatar
kp
maybe i'm just a dummy, but what exactly are you describing when you say "62405A-2s"?
edit: i just re-read your post. yeah i'm an idiot.
Old Aug 25, 2008 | 04:29 PM
JCushing's Avatar
start with them dialed in according to the cam card they came with then go from there. try retarding the exhaust and advancing the intake. do both of those things too far though and good luck idling. im guessing you clearanced these cams right so you know how far you can adjust them?
donF and b19coupe should have some more first hand experiance though
Old Apr 16, 2012 | 05:31 AM
Alvaroteg's Avatar
Hi from Chile, I know this is a older thread...
Do you have some dyno results with the 62405 cams???
I´m interested in those cams, now I running Crower 404 with very good results and my next mod would be the 405.
Thanks in advance...
Old Apr 16, 2012 | 06:10 AM
EsotericImage's Avatar
Retired Moderator
Holy 4 year old bump!
Old Apr 16, 2012 | 10:11 AM
Alvaroteg's Avatar
Yes jaja, I´m interested because there isn´t dynos with the 62405....
vtecmasta85
80
Oct 22, 2015 08:23 AM
Eg9502
Oct 26, 2014 04:58 PM
smileycvc
22
Feb 8, 2007 05:40 PM
Samsonite
Oct 1, 2002 01:54 PM
Stunna BEN
Nov 26, 2001 06:18 AM
