master bushing kit
Old Aug 18, 2008 | 01:02 PM
moco_machine's Avatar
Default master bushing kit
I'm thinking of installing the master bushing kit myself and i also want to install the rear trailing arm bushings. How many parts would have to be pressed on? and is there a tool i can buy that is universal for all the parts that need to be pressed on including the rta?
Old Aug 18, 2008 | 01:10 PM
HOODLOVER's Avatar
Default Re: master bushing kit (moco_machine)
the most difficult for me were the inner lower control arm bushings.. I ended up having to use a torch and air hammer. damn 18 year old bushings!
Old Aug 18, 2008 | 01:33 PM
scottmog's Avatar
moco i am SO sorry for sorta jacking your thread but i was wondering where did u get your master bushing kit?
Old Aug 18, 2008 | 01:37 PM
Default Re: master bushing kit (Mog)
http://www.caeperformance.com
Old Aug 18, 2008 | 02:02 PM
JesseCRX's Avatar
Yeah, but is this for a urethane kit or a rubber bushing kit?
Old Aug 18, 2008 | 02:08 PM
Default Re: master bushing kit (JesseCRX)
energy polyurethane bushing kit and oem trailing arm bushings
Old Aug 18, 2008 | 03:00 PM
marilyn0220's Avatar
I purchased and installed energy suspension's poly complete bushing kit. I bought on ebay from an outlet that i have spent a good bit of money with, no problems, time consuming, but well worth it.
Old Aug 18, 2008 | 03:53 PM
Default Re: master bushing kit (marilyn0220)
so what kinds of press did you use?
Old Aug 18, 2008 | 04:03 PM
spoonfedcrx's Avatar
oem trailing arm bushings just beat out with hammer and tap back in with smaller hammer. shouldnt take more then 10 minutes a side.
the other ones you will need a press or spend forever burning, scraping and cussing them out.
Old Aug 18, 2008 | 04:11 PM
JesseCRX's Avatar
Default Re: master bushing kit (spoonfedcrx)
Does anyone make an oem style rubber bushing kit?
Old Aug 19, 2008 | 09:36 AM
Does anyone know of what kind of press i should use to take the old bushings out and put the new one in?????
jdmem205
Nov 12, 2013 02:35 PM
FakeJDMEF8
Sep 9, 2006 07:52 PM
JokerTypeR
Nov 10, 2005 08:20 PM
sircrxracer
12
Mar 17, 2004 09:05 AM
