k20a2 head on k20a3
Old Aug 18, 2008 | 09:58 AM
newport45's Avatar
Default k20a2 head on k20a3
If i do wind up getting an ep3, which is most likely, will the A2 head go onto an A3 block and will i find obvious power gains? other than swapping the actual heads will i need additional mods, ecu, tuning, etc?
Old Aug 19, 2008 | 09:15 AM
UKDMEP3's Avatar
Default Re: k20a2 head on k20a3 (newport45)
yea man the ep3 comes with A3, and yes the A2 head will bolt right up, the only thing is that you will have to get an dc5, or ep3 type r ecu cause they dont have the immobilelizer in, i was thinkin of considering the swap myself but save the money and get a k24 with an A2 head or jus A head then run k pro and it would be sick and will be makin some power then, or jus boost the A3
Old Aug 20, 2008 | 06:10 PM
simonEp3's Avatar
Default Re: k20a2 head on k20a3 (UKDMEP3)
Old Aug 20, 2008 | 07:52 PM
RedDC5's Avatar
Default Re: k20a2 head on k20a3 (simonEp3)
Wooow. No. Dude, the hassle for getting this head on an A3...you might as well get a swap.
Old Aug 21, 2008 | 03:53 AM
Maconperformance's Avatar
The a2 head on an a3 block could be a hassle. Just boost the a3 and you'll be happy.
Old Aug 24, 2008 | 03:35 PM
Ninja_Ep3's Avatar
Default Re: k20a2 head on k20a3 (RedDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedDC5 &raquo;</TD></TR><TR><TD CLASS="quote">Wooow. No. Dude, the hassle for getting this head on an A3...you might as well get a swap. </TD></TR></TABLE>
Could you please elaborate on this?
What kind of hassle are we talking about exactly? I'm not too keen yet on the K series. It's not as labor intensive as a b series LS/Vtec is it?
and the price difference between a 4300-5500 engine and just a cylinder head seems to kinda help balance things out in favor of just a head swap.
Old Aug 24, 2008 | 06:47 PM
simonEp3's Avatar
Totally agree just pick up an A2 swap
Old Aug 24, 2008 | 07:02 PM
WhiteOnRice's Avatar
The major reason an a2 swap is quicker is the higher compression and shorter transmission, not so much from real vtak.
Old Aug 25, 2008 | 05:25 PM
UKDMEP3's Avatar
hey man the one reason why it is a pain in the *** to do is because u have to take everything apart u have to take the intake manifold, and exhaust manifold off, disconect all the hoses, the wirning harness, and a bunch of other **** too,ur almost close to pullin the motor for all that work all u have left is like the shift linkage, motor mounts, that weird *** box the motor sits in (cant think of the real name for it), the axles and a few other things, for all that work u might as well save the money and get an a2 swap u have to change ur ecu anyways to run the real vtec in the a2 head
Modified by UKDMEP3 at 6:30 PM 8/25/2008
Old Aug 25, 2008 | 08:46 PM
Ninja_Ep3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UKDMEP3 &raquo;</TD></TR><TR><TD CLASS="quote">that weird *** box the motor sits in (cant think of the real name for it)
Modified by UKDMEP3 at 6:30 PM 8/25/2008</TD></TR></TABLE>
You mean the cradle?
ok so basically, becuase of basic installation issues and all it's worth spending 5 grand? I can understand not wanting to do all that work, but i do look at it as being a project. I dunno, I mean in all truth i eventually would like the 6 speed. unfortunately that means i'd have to wait quite a bit longer till i could afford to swap an entire engine as opposed to the head, ecu and other parts. But whatever.
Old Aug 26, 2008 | 05:36 AM
$5k??? I'll sell you my a2 for $3k with everything you need to get it into an ep.
mikej94civex
Jan 11, 2010 02:20 PM
WagonKore
Dec 3, 2006 12:39 PM
Turbo_y8
Feb 25, 2006 07:11 PM
02ep3
28
Dec 16, 2005 12:39 PM
