homemade shift light?
Old Jul 23, 2002 | 11:11 AM
SpeedMonkeyRacing's Avatar
Default homemade shift light?
does anyone have any website or info about how to make those? i can't stand those huge *** shift light..i just want ot make a little one that blinks when i hit redline
Jeff-
Old Jul 23, 2002 | 11:12 AM
Hcivic88's Avatar
Default Re: homemade shift light? (Corporal-Jeff)
just like a little L.E.D or something, yeah, that would be nice. and you could just hide it somewhere in your dash instead of on top like those big ones
if theres a cheap and easy way to do that, i think i might try it. ill add it to my list of things to try, i think the next thing is a teg center console
[Modified by Hcivic88, 12:13 PM 7/23/2002]
Old Jul 23, 2002 | 11:28 AM
89 CRX SI's Avatar
Default Re: homemade shift light? (Hcivic88)
cant find the site with the circuit on it. But it wont cost more then 20 bucks. you can alwys but a rpm activated switch and run a LED off that. thats prolly then best way.
You can do it for about 3 bucks if you make you own RPM activated switch . it should be easy to find a sceatic for that on the net
Old Jul 23, 2002 | 01:23 PM
Hcivic88's Avatar
Default Re: homemade shift light? (89 CRX SI)
hey $3, i like the sound of this.
89 CRX Si, you wouldn't happen to have more detailed instructions, would you?
the main question i have, is with the RPM activated switch, how do you set it to the RPM you want, all you'd need though is the switch running from the LED to the blue wire on the dizzy or off the tach in your cluster if u have one(i do), and a ground for the LED, right??
89 CRX - good idea, i never even though of that, this may turn out to be a fun project. might do it this weekend if i get that switch
[Modified by Hcivic88, 2:24 PM 7/23/2002]
Old Jul 23, 2002 | 01:26 PM
Hcivic88's Avatar
guess what I found???
Old Jul 23, 2002 | 01:30 PM
damn..nobody thank me for thought about this idea
Jeff-
Old Jul 23, 2002 | 01:32 PM
Hcivic88's Avatar
thank you Jeff
Old Jul 23, 2002 | 01:36 PM
hehehehe..
Jeff-
Old Jul 23, 2002 | 01:41 PM
hmmm...now to think about it..i wonder if it's possible to do it w/ v-afc
Jeff-
Old Jul 23, 2002 | 01:45 PM
Hcivic88's Avatar
dont get it too complicated now
Old Jul 23, 2002 | 01:46 PM
hehehehe....i'm trying not to
Jeff-
Old Jul 23, 2002 | 01:50 PM
Hcivic88's Avatar
i really want to try and figure out how to make one of those switches... anyone have any idea how???
Old Jul 23, 2002 | 01:53 PM
Lamchop0000's Avatar
that diagram confused me
Old Jul 23, 2002 | 03:28 PM
specie's Avatar
Default Re: homemade shift light? (lamchop0000)
http://www.hondacrx.org/shift.htm
Old Jul 23, 2002 | 04:50 PM
Mugen Dom's Avatar
Jeff-
yes very possible instead of using vtec selenoid use the shift light but it only goes to 7 K i think
Old Jul 23, 2002 | 05:07 PM
89 CRX SI's Avatar
wel a rpm activated switch uses so called pills to activate the switch at a given RPM. most switches will come with 10 or so pills. these pills are basically little resistors that plug in the saide changing the kick in point.
product would say:
RPM ACTIVATED SWITCH 5000 rpm-7000 rpm
and you would have pills that read on them 5000rpm - 5200 rpm and it would flip the switch to run what ever between those rpm's. GET it?
ill find the scematic for making the actual rpm activated switch later. its simple only requires about 1$ in parts and 1$ in solder and 1 $ in a Circuit board
jamie03
Dec 11, 2005 05:59 PM
joker1626
Oct 17, 2003 03:01 PM
bc_psychocivic
Sep 20, 2003 06:35 PM
revhigh96
Mar 19, 2003 07:38 PM
curiousgpnoy
Dec 3, 2002 04:45 PM
