GSR transmission on an LS motor: worth it?
Old Aug 17, 2008 | 09:45 PM
Neptronix's Avatar
Default GSR transmission on an LS motor: worth it?
So i'm still waffling on what the hell i want to do with my car, but i've always wanted more low end response.
I hear a GSR transmission perks things up by increasing rpm's. I tend to drive at low rpms (1.5k-2.25k ) while cruising but like to downshift to kick *** from time to time.
So one question.. are the gears shorter like on a transmission intended for a smaller motor? or do they just run at a higher rpm?
what i'm looking for is a little more pickup, even from low rpm.
will the gsr transmission do this for me?
Old Aug 17, 2008 | 10:03 PM
JDM_CRX_PLEASE's Avatar
the GSR tranny has shorter gears so you will feel somewhat of an acceleration since the gears are shorter.
my friend ran a gsr LSD tranny in his 4door LS and he kept up with my b16A civic coupe pretty well. but when i hit 3rd i was pulling. but his LSD and gsr tranny helpd. if it was stock LS then yah he wouldnt have had such a chance.. also he had cams he told me and he got it tuned for fun.
Old Aug 17, 2008 | 10:28 PM
TOO MUCH TORQUE's Avatar
definitely faster, but youll be cruising at higher rpms your car is use to. btw the ls engine is bigger than GSR
Old Aug 17, 2008 | 10:37 PM
Neptronix's Avatar
Default Re: (TOO MUCH TORQUE)
Yeah, i do know that. I know i'm not going to like the 5th gear. I was thinking of swapping that out with an LS gear. Honda shop dude tells me this is easy once you get the tranny apart.. anyone know if there is truth to that? it matters to me because i do a lot of highway.
also kind of considering a USDM ITR transmission with an LS 5th because on the GSR trans, the difference is mainly in the final drive. But i take it the USDM ITR trans is pretty friggin' expensive.. but 2nd-4th would have quite a kick..
Old Aug 17, 2008 | 11:19 PM
Neptronix's Avatar
Default Re: (Neptronix)
Wait a minute. I just thought of something.
I'm looking for the lower gears to be quicker, ultimately. I don't think there is a such thing as a stronger first.. how about just swapping final drives? hmm!
can this be done? a 4.4 out of GSR trans or from elsewhere on a LS transmission? Then i don't even have to get another transmission.. or worry about swapping my 5th.
Old Aug 18, 2008 | 10:06 AM
cetcivic's Avatar
no one wants to hear the truth
IVE SEEN A THREAD ON HERE THAT EXPLAINS ALL THIS..SEARCH:TRANSMISSION GEAR RATIOS..GOOD LUCK
Old Aug 18, 2008 | 10:11 AM
hatchling37's Avatar
It'll be fairly straight forward when the case is apart. You need to swap out countershafts with the LS 5th.
Old Aug 18, 2008 | 10:14 AM
redDAinteg's Avatar
Default Re: (cetcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">Wait a minute. I just thought of something.
can this be done? a 4.4 out of GSR trans or from elsewhere on a LS transmission? Then i don't even have to get another transmission.. or worry about swapping my 5th.</TD></TR></TABLE>
This will not work as you think it will. You will have overall shorter gears by swapping the final drive, but the gears will still have the same difference from each other. Which means you will still have a TALL 3rd, 4th and 5th gear regardless of the final drive just because of the gear ratios.
Also fyi, the usdm type R transmission gear ratios are the exact copy of a b16 transmission, only with dual synchro on every gear and the LSD. The GSR transmission is overall longer than a b16/type R trans.
Old Aug 18, 2008 | 10:22 AM
dcfreak's Avatar
Default Re:
i think you might like it i got a 98 itr on my ls and it runs great just on the highway im at about 5000 at 80. but over all i like the pull.
Old Aug 18, 2008 | 10:38 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Re: (dcfreak)
buy my usdm 98'' spec gsr tranny with ctr LSD and stg2 clutch kit cheap!!
https://honda-tech.com/zerothread?id=2367321
Old Aug 18, 2008 | 10:57 AM
Neptronix's Avatar
Default Re: (redDAinteg)
i am ok with tall 3rd, 4th, and 5th gears.
what i'm looking for is a stronger launch off the line and in general. First and second being the most important. But the only OEM 2nd gear i can find is the type R.. and it looks like 1st gears are the same all around, so why not just keep things simple and not change any of my gears.
and for dcfreak.. i'll pass on the 5000rpm 5th gear idea. i do mainly highway. otherwise i'd just swap a gsr transmission in there and call it a day.
Old Aug 18, 2008 | 11:00 AM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">definitely faster, but youll be cruising at higher rpms your car is use to. btw the ls engine is bigger than GSR</TD></TR></TABLE>
do wha?
Old Aug 18, 2008 | 11:13 AM
Neptronix's Avatar
Default Re: (Honda Tool)
it's bigger, by like 37cc. but it's built for more low end power, so the higher rpm it runs while cruising, the worst off it is as far as gas mileage. that's one reason why you don't want to be going 7000134200rpm at 14mph.
Old Aug 18, 2008 | 11:21 AM
wunfstgsr's Avatar
Loved
Community Favorite
what i'm looking for is a stronger launch off the line and in general. .</TD></TR></TABLE>
You should just get a LSD instaled and call it a day
Old Aug 18, 2008 | 11:23 AM
na+b18c_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">definitely faster, but youll be cruising at higher rpms your car is use to. btw the ls engine is bigger than GSR</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Tool &raquo;</TD></TR><TR><TD CLASS="quote">
do wha?</TD></TR></TABLE>
yeah, uhhh... ls and gsr are both 1.8 liters bud.
Old Aug 18, 2008 | 11:51 AM
Neptronix's Avatar
Default Re: (wunfstgsr)
i'm not looking for that kind of launch, i want shorter gears without having my 5th rpms be super high at 70mph.
the vtec dohc 1.8 motors are 1797cc and the dohc 1.8 is 1834cc. torque/hp curves are quite different, also.. but that's besides the point!
Old Aug 18, 2008 | 11:59 AM
i didn't know we were splitting hairs (which is the difference in size), but are they both not 1.8 liters?
Old Aug 18, 2008 | 12:05 PM
Neptronix's Avatar
Default Re: (na+b18c_hatch)
technically yes, they are both.
but completely different torque curve. ( you should see the ITR.. it's a limp dick until 6000rpm, then it takes the hell off. )
You don't really want the LS running 4000+rpm on the highway. I think in my transmission i have to be at 85, or 90mph to hit that. at 70mph i run at about 3000rpm.
still not clear on wether or not you can swap a 4.4 final drive into a B18B trans.
I searched and found some post in '04 that didn't really make things clear.
Old Aug 18, 2008 | 12:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">technically yes, they are both.
i used to have a type r, and my wife has an rs. there's no way in HELL that the rs would walk the itr off the line. the torque curve might look that way on paper, but after driving both, there's no way.
Old Aug 18, 2008 | 12:28 PM
Neptronix's Avatar
i'm talking about the torque curve of the motor itself.
that's why they add a nutty, high revving transmission, especially at higher gears... so you can pass on the highway in 5th with no prob.
Old Aug 18, 2008 | 12:38 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptronix &raquo;</TD></TR><TR><TD CLASS="quote">still not clear on wether or not you can swap a 4.4 final drive into a B18B trans.</TD></TR></TABLE>
The 4.4 from a B16A tranny will bolt onto the LS differential. The 4.4 from a GSR or ITR tranny will not.
Old Aug 18, 2008 | 12:47 PM
Neptronix's Avatar
Default Re: (Kendall)
hm. you're talking about a b16a ( cable ) transmission?
geez, what is the b16a cable tranny from, a late 80's integra?
Old Aug 18, 2008 | 01:07 PM
naler62188's Avatar
The 92 integra XSi came with that tranny.
Old Aug 18, 2008 | 01:11 PM
Neptronix's Avatar
Default Re: (naler62188)
oh mama! that's got the type r gearing.
Could i stick 'dem gears in my b18b?
Old Aug 18, 2008 | 01:42 PM
cetcivic's Avatar
'94 Del Sol S - STOCK - sold to girlfriend
^i should be like you,i'd have more money to mod my car^
