need HELP with b20 swap in a 91 si hatch.....any gurus help.
the other thing that i know is that to convert it to obd-0 i need the ls intake manifold and distributor. i already have the halfshaft and tranny and im getting the motor soon.and im also buying new clutch and mounts....is there anything else i need.
why can no one has search?
B swaps are very common and everything about them is covered.
Use the FAQs also.
Use the FAQs also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote">why can no one has search?
Use the FAQs also.</TD></TR></TABLE>
Agreed x 2
B20 swap is identical to an LS swap, you can even run the same ecu. It is a very easy and worthwhile swap for sure. The one in my civic rocks.
Only other advise i'll give since your in the market is......pay the extra coin and find the later gen model with higher compression known as a B20Z. It makes a lot more power.
Agreed x 2
i already have a brand new b series shift linkage. now my other question is will the ls axles fit in my 91 hatch hub.
ok look just to make everything easy can anyone plz go out of their way for a second and list all the parts i need for the b20 swap? i dont mean to bother is just that i need to know. srry i i caused any inconvenience.
I have a complete LS intake manifold from Throttle body, to fuel rail and injectors. guy_from_nerk@hotmail.com
email if interested
email if interested
I've got a PR4 ECU and LS intake / tb. PM if your interested.
Here's another LS link for you http://www.geocities.com/speed...p.htm
