94 grs tranny problems
Old Aug 17, 2008 | 05:45 AM
biggrin5's Avatar
Default 94 grs tranny problems
ok i resiantly put in a stage two clutch masters clutch and alumiunam fly wheel. once i had it driving again it drove fine but after a little driving things started going wrong.
while at idle the car doesnt like going into first or second gear unless you put the car in 3rd 4th 5th or reverse the in first or second.
aslo when the car is in first at a idle the clutch begins to grab and in some cases stall out. the car has a new slave cylinder also ans i have bled it many times.
any suggestions... i guess the bearings in the tranny are going but i just would like some input
Old Aug 17, 2008 | 05:57 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: 94 grs tranny problems (biggrin5)
Sounds like the pressure plate is not fully releasing the clutch plate.
Check the clutch line for fluid leakage, also the clutch MC could be on it's way out
hitvtecgetloud09
Aug 6, 2005 08:55 PM
KB96VTEC
Apr 27, 2005 05:40 PM
ZeroGSR
Oct 1, 2004 01:49 PM
Ditdogs
Apr 4, 2004 07:44 PM
