poor r wont start
Old Aug 17, 2008 | 05:08 AM
mudd_butt's Avatar
Default poor r wont start
hi i just did a poor man r with ctr piston with b16 head
ok the problem is im using stock injectors if i spray starting fluid in there throttle it will start but after it burns all the fluid the motor shuts off im thinking its my injectors not big enough have any of ya try this or have this problem my cuz did a ctr piston gsr and he have stock inector but his start i dont know heellpp
Modified by mudd_butt at 6:56 AM 8/17/2008
Old Aug 17, 2008 | 06:14 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: poor r wont start (mudd_butt)
first of all check your cam timing to make sure everything lines up at TDC. If that's good, check to make sure your ignition timing is correct. Are you using adjustable cam gears? what type of cams? are you using any engine tuning such as Neptune etc?
Old Aug 17, 2008 | 07:12 AM
mudd_butt's Avatar
Default Re: poor r wont start (00Red_SiR)
aem tru time camgear on 0 degree
Old Aug 17, 2008 | 07:16 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mudd_butt &raquo;</TD></TR><TR><TD CLASS="quote">aem tru time camgear on 0 degree </TD></TR></TABLE>
what about everything else I mentioned?
Old Aug 17, 2008 | 07:34 AM
JDM_DC4_Fanatic's Avatar
4 basic things an engine needs to run
1) decent compression (above 150 minimum)
2) fuel (make sure the injectors are pulsing)
3) air (obviously its getting air if the intake is off, and u have an open tb)
4) Timed spark. Like mentioned before, make sure that the engine is timed properly. Both ignition and cam timing.
something tells me you havent checked all 4 of those things. If the injectors were too small, the engine should still run, but it would run lean as hell.
Old Aug 17, 2008 | 10:37 AM
mudd_butt's Avatar
Default Re: poor r wont start (JDM_DC4_Fanatic)
tdc ?
the shop set at this line is it correct or not
I I I ..........I
..1 ...........2
thats my pully drawing of the marks on the pully is 1 tdc or mark 2 tdc
mine is at mark 2 rite now
Modified by mudd_butt at 11:42 AM 8/17/2008
Modified by mudd_butt at 11:43 AM 8/17/2008
Old Aug 17, 2008 | 05:20 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mudd_butt &raquo;</TD></TR><TR><TD CLASS="quote">tdc ?
tdc = top dead centre. If you don't know how to check these things or set them, then take your car to someone who does.
Old Aug 17, 2008 | 10:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
tdc = top dead centre. If you don't know how to check these things or set them, then take your car to someone who does.</TD></TR></TABLE>
QFT!
op =
Old Aug 18, 2008 | 09:24 AM
acydphryck's Avatar
check your fuel pump if it's running...it would also help if you have some fuel in the tank. does your fuel gauge work?? just making sure these simple items were checked off the list
Stray
Jul 5, 2007 12:33 AM
Speed Infliction
Feb 7, 2007 10:13 PM
qp
17
Nov 22, 2005 09:25 PM
92HB_HB
Feb 13, 2005 06:05 AM
